Posted 11 August 2009 - 10:26 PM
Posted 13 August 2009 - 10:10 PM
Posted 16 August 2009 - 08:02 PM
Edited by mandarinvx, 16 August 2009 - 08:02 PM.
Posted 16 August 2009 - 08:14 PM
Posted 16 August 2009 - 08:24 PM
Posted 16 August 2009 - 08:41 PM
Posted 16 August 2009 - 08:45 PM
terrific thread - i remember seeing it at meguires day.
Posted 16 August 2009 - 08:56 PM
Posted 16 August 2009 - 08:59 PM
Posted 16 August 2009 - 09:03 PM
Posted 16 August 2009 - 09:17 PM
To do it properly you have to take the whole front end of the car off (the bonnet can stay on), which can be hard work if the fasteners have seized; so it looks like this:is there much involved in taking off the front v and the badge ,do you have to take the bottom of the car to undo it.
Posted 16 August 2009 - 09:29 PM
dam sounds hard then it is the reason why is i think it looks better debadge and degrilled so i might have to have a look at taking the clam off.To do it properly you have to take the whole front end of the car off (the bonnet can stay on), which can be hard work if the fasteners have seized; so it looks like this:is there much involved in taking off the front v and the badge ,do you have to take the bottom of the car to undo it.
That's because the V is held on by screws from behind the grille
You could always cheat and hack it up with a Dremel, but be very sure you want to remove it as it'll be a real PITA to replace it, and you'll have to splash out for a new one
You could always mask/cover the car and spray yours in situ if it's looking a bit worse for wear
Posted 16 August 2009 - 09:35 PM
Posted 16 August 2009 - 09:46 PM
Posted 16 August 2009 - 09:48 PM
Mainly applicable if you take the car on track - the VX has a nasty habit of throwing oil out of the gearbox breather, which then covers the engine bay, and if you're unlucky (as I was in my last car whilst going round Abingdon track) it will also go all over the nearside rear wheelwhat the reason behind this mate
Posted 16 August 2009 - 09:55 PM
Posted 16 August 2009 - 10:01 PM
Posted 16 August 2009 - 10:06 PM
Posted 18 August 2009 - 12:36 PM
Posted 18 August 2009 - 08:59 PM
I managed to spend most of Saturday on it last week, don't get much time outside in the evening tho (that may change when I come to do rear clam / exhaust tho!)Lovely Stuff mate.
Do you work on it at weekends or just a few hours a day ?
Jim
