My New Project
488 replies to this topic
#361 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 30 August 2009 - 11:01 PM
In the instructions for the Eliseparts removal tool it says to cut away the rubber boot. Did you not bother? Only ask as it is not clear in the picture but also because I cut away most of the rubber but did not remove all of it and ended up sandwiching the metal wire ring that holds the rubber boot in place between the wishbone and the removal tool :tt: Grrr :dry:
I didn't bother removing the boot, but as with your experience the retaining rind got caught up so took a bit of effort to remove the spacer :rolleyes:
Hopefully I'll be getting some 12.9 bolts to replace the 8.8s that come with the kit :)
#362 slindborg
Posted 31 August 2009 - 11:57 AM
did the drivers side today with my bodge modded tool :lol: taking the boot off is a piece of p*ss and makes the job 100 times easier :D I now use the slim spacer that you use to remove the joint, to install it too as I found on a couple of joints the press stopped and the joint wasnt home fully. Gonna get a friend to make me a new tool with strong threads etc :D
#363 mandarinvx
mandarinvx
  • 12,621 posts
Posted 31 August 2009 - 12:09 PM
If you need some 12.9 bolts let me know thumbsup When Matt did my first one we managed to stretch the 8.8's (by quite a bit!)
#364 mandarinvx
mandarinvx
  • 12,621 posts
Posted 03 September 2009 - 08:59 PM
Thought I best add this, as effectively it's my service history :D
I had the oil changed about 5k ago when I had the geo done at Guglielmi's, but they couldn't get the oil filter cap to budge whatsoever. I've also tried and failed since
So last weekend had another go, and it finally gave (by using one of the socket adaptors available on ebay - linky)
In fairness the 'adaptor' piece came with it too, so the cap itself is still stuck tight (which is actually a good thing) thankfully the filter can still be withdrawn without removing the inlet manifold - I'm not sure why Vaux made the whole thing so complicated
Pic of the housing with new filter and the two oil cooler rings
Then drained the oil, despite looking a bit black it was actually very clean :)
The old filter - again not in bad nick
And refill with Silkolene Pro-S bought from Opie Oils for the same price as Halfords sell their generic stuff!
Re-assembled it all and went for a spin - bugger - slight oil leak, only very small but enough to make me want to put it right
Searched around and came to the conclusion it was likely to be the oil cooler rings, so went down to Vaux earlier in the week and they actually had them in stock - only £2.80 each too :) There is a small ridge in the ring that gets compressed when tightened, I guess that's why they tend to need replacing quite regularly after an oil change
All seems to be fixed now :D
Also sprayed the tow eye (because I was bored :lol:)
#365 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 04 September 2009 - 05:02 PM
I change the oil on my vectra every 5 years and last time i did it i filled it 4 times with fresh oil letting it warm up between draining, just done it again 5k later and even the first lot i dropped wasnt very black, and its a diesel so it usually goes black when you show it to the car :)
#366 mandarinvx
mandarinvx
  • 12,621 posts
Posted 04 September 2009 - 06:57 PM
every 5 years
:blink: :o
#367 Zoobeef
Zoobeef
  • 11,103 posts
Posted 04 September 2009 - 07:06 PM
Haha thats me writing and thinking of something else again, dont know how many times ive been picked up for my writing, that should be 5k
#368 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 04 September 2009 - 07:53 PM
Sorry, defo a waste of money on a Vectra. :rolleyes:
#369 Zoobeef
Zoobeef
  • 11,103 posts
Posted 04 September 2009 - 07:56 PM
I think not, I paid £800 for it 3 years ago and never caused me a moments trouble, and i do 4-500 miles a week. And all my oil is free for it :)
#370 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 04 September 2009 - 08:02 PM
Well, it's hard to waste free! thumbsup
#371 Zoobeef
Zoobeef
  • 11,103 posts
Posted 04 September 2009 - 08:05 PM
Its does make me cringe using 20ltrs of oil to service it but as long as my car stays happy then im happy
#372 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 05 September 2009 - 06:15 AM
Totally excessive. :rolleyes:
#373 slindborg
Posted 19 September 2009 - 07:14 AM
Adam, I trust you got anew oil seal for the filter cap.... and the lovely fisting that vaux give you for a new one these days :( new dampers soon huh ;)
#374 mandarinvx
mandarinvx
  • 12,621 posts
Posted 19 September 2009 - 12:16 PM
There was an O-ring in the box with the filter, but as the top cap wouldn't come off I haven't changed it
#375 mandarinvx
mandarinvx
  • 12,621 posts
Posted 25 September 2009 - 07:18 PM
New Gaz monotubes fitted last weekend - first impressions are great :D
#376 mandarinvx
mandarinvx
  • 12,621 posts
Posted 25 September 2009 - 07:22 PM
Decided to remove the rear clam today - I have loads to do under there, but the priorities are to fit the Piper 2.5" and get the Spitfire toe link kit on :)
Despite what Joe may try and tell you it isn't easy, and it doesn't take 30 minutes :lol:
Did it the full way so I can remove the sound deadening behind the parcel shelf :)
At last...
And this may explain the mild tick whilst cold :lol:
Thankfully to be replaced with the Piper 4-1 B)
#377 vocky
Posted 25 September 2009 - 07:49 PM
now thats a cracked manifold :rolleyes:
#378 mandarinvx
mandarinvx
  • 12,621 posts
Posted 25 September 2009 - 08:57 PM
I must admit, after seeing it, I'm surprised it didn't sound much louder!
#379 Rocky
Rocky
  • 96 posts
Posted 26 September 2009 - 06:16 AM
Why the change of shocks so soon? Were you not happy with the Gaz Gold pro's? Whats the differance between the golds and the monotubes?
#380 mandarinvx
mandarinvx
  • 12,621 posts
Posted 26 September 2009 - 10:37 AM
The Golds were great B) But Gaz needed a car to play with to make sure the monotubes have the correct level of damping adjustment, so I volunteered :D; they also made a few mods to the body lengths on the day thumbsup
    Bing (1)
