Posted 02 September 2017 - 04:16 PM
Posted 02 September 2017 - 04:21 PM
288 or 295 rears chris,
Posted 02 September 2017 - 04:39 PM
288,
Posted 02 September 2017 - 04:43 PM
Edited by CHILL Gone DUTCH, 02 September 2017 - 04:45 PM.
Posted 02 September 2017 - 06:28 PM
Posted 02 September 2017 - 06:35 PM
They are the same thickness as the AP ones
pull your finger out Chris, almost there!
Posted 02 September 2017 - 06:37 PM
Quite sure they will crack if used on track... they are too thin like the EP ones!
i wont be happy if they do.. fingers crossed they are ok..
Posted 02 September 2017 - 06:38 PM
They do look the part, what's the plan for engine. And nice to see the painted Avon logo
its the reflection, i wouldn't ever paint my tyre logos.
Posted 02 September 2017 - 07:14 PM
Posted 02 September 2017 - 07:25 PM
Edited by pete-r, 02 September 2017 - 07:28 PM.
Posted 02 September 2017 - 08:13 PM
Posted 02 September 2017 - 08:30 PM
Posted 02 September 2017 - 11:17 PM
yea the weight saving is from my old setup. 308 & 288
Posted 03 September 2017 - 06:32 AM
Looking Mint Chris lots of work going into it good Job .
Posted 03 September 2017 - 03:47 PM
Posted 03 September 2017 - 07:15 PM
Hope that's enough
Posted 05 September 2017 - 11:47 AM
Like the stone guards Chris - seen those somewhere else ???
Posted 10 September 2017 - 04:25 PM
Finally stuck my replacement window in, its a twin layered piece with foam core, on the inside i have stuck some alacantara on to make it slightly more comfortable inside.
also, got the supports done in gold, for no other reason than the original paintwork on them was gash, so they needed to be re-done so i figured gold.
removed the rubber and replaced with 1mm carbon sheet, much stronger and it wont bend when air hits it.
i used a 3mm camber shim to crudely attached my water pump for the CC system to the bulkhead, its only temporary atm until i figure something better to use to mount it.. Im going to use some rubber to keep vibrations to a minimum.
Edited by chris_uk, 10 September 2017 - 04:27 PM.
Posted 10 September 2017 - 04:32 PM
Edited by CHILL Gone DUTCH, 10 September 2017 - 04:33 PM.
Posted 22 September 2017 - 09:26 PM
