Vx220 Project
396 replies to this topic
#361 chris_uk
Posted 19 October 2017 - 09:26 PM
some other pics of the tank
the baffle, we wanted to make a baffle which would give us the most accurate reading.
this was the first design, but after testing we found that it was too small and it had too many holes..
so i re-designed it completely and ended up with this.
#362 chris_uk
Posted 05 November 2017 - 12:03 PM
little update for those still reading.
Tank is almost finished, it holds 5.5L of water, not including the pipework etc which we think will add at least another litre.
started off by making the surge pot where the outlet pipe is for the pump.
inner bead, these are so hard to do for me, the base is 1.2mm and the edge was 0.7 so it just eats right through.. managed to get a really nice bead going here for a little bit..
filled with water and hey presto.. no leaks.. :o
started with the lid then,
this is going to be the filler neck which is welded to the inside of the lid
made some heat sinks out of ali..
unfortunately i didn't get any of the finished ones as it was late and we turned in for the night, in the morning we tacked it up and realised, so its staying on.
#363 CHILL Gone DUTCH
Posted 05 November 2017 - 06:58 PM
Looks well chris but i Do have a question Is that float switch in the baffled area ? If so surely it would be better to have the water outlet for pump in the baffled bit rather than the float as you would want the float switch to operate before the water runs out
#364 chris_uk
Posted 05 November 2017 - 08:02 PM
Underneath the baffle there are holes which run straight into the surge pot, these allow the water to run out fast enough that the baffle will never be ful and the surge pot close to empty
#365 CHILL Gone DUTCH
Posted 05 November 2017 - 08:23 PM
ah so you have a second tank under the main tank
#366 chris_uk
Posted 05 November 2017 - 08:24 PM
yes, its a much smaller compartment which the filter sits in.
#367 CHILL Gone DUTCH
Posted 05 November 2017 - 08:40 PM
might be worth putting some holes in the baffle plate lower down to make sure the water dosent run out of the float section and a lot of water still in the main section of the tank
or maybe even a hole on the bit with a slant
#368 chris_uk
Posted 14 March 2018 - 03:36 PM
The level float is in the main tank, but it is baffled just to try stop it activating it when its under G.. under that is the smaller compartment which is just a bit bigger than the filter for the main feed.. on fully empty there would be less than 10mm in the tank so waste is at a very minimum.
#369 chris_uk
Posted 15 March 2018 - 11:14 AM
Work is really progressing on mine now! I managed to get more done last night than i have in 3 months!! I fit my new 6pk1290 belt and i bolted in my caliper brackets after alighning them correctly... but left the 1/2 to 3/8 adaptor at work so i did everything up hand tight and finished for the night proud of the acomplishments i had made.
#370 Talk-torque
Talk-torque
  • 150 posts
Posted 15 March 2018 - 12:46 PM
Good to hear Chris. Back on the road soon?
#371 chris_uk
Posted 15 March 2018 - 12:59 PM
I hope its done for the end of april.. although some things will have to be postponed until this winter
#372 chris_uk
Posted 23 May 2018 - 08:49 PM
Car is now finished, managed to get it finished the day before my first track day at blyton.
#373 chris_uk
Posted 23 May 2018 - 08:53 PM
Bought Glens old spoiler as i fancied a change, so i put that on tonight, looks ok i think.. im sure it will work better too.
#374 chris_uk
Posted 31 May 2018 - 08:26 PM
I went to Pheonix Motorsport today for a natter and i put the car on the scales and the weight came in at exactly 930KG with a full tank of fuel.. with me in it went up to 1019kg. I need to go on a diet! .lol
#375 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 31 May 2018 - 09:34 PM
What were your corner weights like with you in it?
#376 chris_uk
Posted 31 May 2018 - 10:54 PM
i couldn't tell you..
without me it was 175 ish front and 270's rear, but the floor wasnt flat flat, it was just setup to get the weight.
#377 siztenboots
Posted 01 June 2018 - 03:44 PM
what has made it heavier?
#378 chris_uk
Posted 01 June 2018 - 04:44 PM
i assume you mean from a standard car.?
coupe and hardtop weight 30kg.
supercharger and front mounted charge cooler must be nearly 20kg
the wheels i am using are really heavy, much more so than standard
spoiler, diffuser, front splitter  they will weight about 10kg if not more, combined.
#379 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 01 June 2018 - 10:57 PM
Out of interest have you ever considered basic TDs Chris?
#380 chris_uk
Posted 01 June 2018 - 11:15 PM
had them on before, they were fine, just everyone has them and i dont think it suited my car..
