Vx220 Project
396 replies to this topic
#161 chris_uk
Posted 31 March 2014 - 07:38 AM
Well for us who have moved the ecu from standard position to accomodate for the supercharger usually use the chassis earth on the pax side near the air filter, thats what i did anyway. So if i did connect it up to the ecu it would only be going back through the chassis anyway. Im probably best finding my original earth arnt i..
#162 Exmantaa
When I move my SC-ecu's, I simply use the existing loom earth wire that is connected to the engine (intake cam cover). Doesn't really matter where you ground your ecu, as long as you use the same point for your sensors as Arno has described. (But I would always ground it to the engine.)
WB-AFR is pretty important if you map your engine to that voltage reading... :happy:
Edited by Exmantaa, 31 March 2014 - 07:46 AM.
#163 chris_uk
Posted 31 March 2014 - 07:59 AM
Cheers frank, arno.. Best find my ecu earth.. God knows where it is tho. Ha.
#164 chris_uk
Posted 04 May 2014 - 02:25 PM
i thought i had best give the car a wash.
so i gave it a wash and whilst i was at it i put the old turbo spoiler back on to aid the rear aero.
dunno if i prefer the look or not yet..
i wondered what it would look like if i took off the rear spoiler.
not keen.
#165 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 04 May 2014 - 03:17 PM
Is your rear diffuser spaced down? If so is your rear towing eye still on the normal place? When I spaced it down I though it looked a bit weak with a spaced/extended bolt.
#166 chris_uk
Posted 04 May 2014 - 03:49 PM
the 2 fixings at the back are normal, ive just bent it down if you know what i mean.
#167 Zoobeef
Zoobeef
  • 11,103 posts
Posted 04 May 2014 - 04:47 PM
Thought that might be the case. I'll look at doing that. Won't make the underneath of the car as nice and flat though.
#168 chris_uk
Posted 04 May 2014 - 05:41 PM
as far as im aware the rear of the car (diffuser) doesnt want to be flat, it wants to point up as much as possible..
#169 Zoobeef
Zoobeef
  • 11,103 posts
Posted 04 May 2014 - 05:45 PM
By stepping down the back but not those main 2 bolts it'll make it flatter actually as it's lifting the front up and rear down. But closer to the floor is a good effect. Just depends which attribute is more important haha.
#170 dewismotorsport
dewismotorsport
  • 124 posts
Posted 04 May 2014 - 10:54 PM
As on CS car looks great I do like the red and black theme
#171 chris_uk
Posted 04 May 2014 - 11:01 PM
cheers mate.
#172 chris_uk
Posted 11 May 2014 - 05:32 PM
#173 chris_uk
#174 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 May 2014 - 06:15 PM
Looks good mate. How strong are the gaps between it? Are you doing mesh?
#175 chris_uk
Posted 11 May 2014 - 06:18 PM
yes they will be meshed, just gunna wait until i do the rear as well so i can do it all in 1 go.
#176 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 May 2014 - 06:31 PM
Makes sense. Are you doing the arches to?
#177 chris_uk
Posted 11 May 2014 - 07:06 PM
yea, be no point in the vents if i didnt.. ive got some filter material that my pop uses for his pond and it lets loads of air through so that should stop all the dirt and stones flying up onto the windscreen.
#178 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 11 May 2014 - 09:06 PM
Nice work, your car is amazing!
#179 chris_uk
Posted 17 May 2014 - 08:06 PM
Finished my front vents
Cut and meshed the inner arches
Also cleaned up the chassis a bit.
And all finished
And what it looks like from inside.
#180 TazN
TazN
  • 2,931 posts
Posted 17 May 2014 - 08:25 PM
I'm surprised how close the wheel arch gets to the backside of the clam. Looks really good and certainly different to the usual louvres.
