How Do I Switch The Airbag Light Off ?
Posted 02 March 2009 - 06:59 PM
Posted 02 March 2009 - 07:04 PM
I have fitted harnesses and a harness bar in my car now, removed the old seatbelts (thus disconnecting the little wire that they were attached to) and the annoying airbag light is staying on permanently now
Presumably this is some sort of safety thing. What are my options to stop the light please?
To remove it permantly you will either have to refit the standard belt and take it to a vxl garage with a tech2 and reset the ecu
Or solder a resistor inbertween the connection and again get a tech2 to reset
The personal obd unit you can get off ebay wont be able to clear the airbag fault code
Posted 02 March 2009 - 07:05 PM
Posted 02 March 2009 - 07:13 PM
You'll need to fit a resistor to the seat belt pre-tensioner circuit to fool the car into thinking they are still there and operational.
Anyone know what size resistor?
cheers
john
Posted 02 March 2009 - 07:15 PM
Posted 02 March 2009 - 07:24 PM
Posted 02 March 2009 - 07:38 PM
Posted 02 March 2009 - 08:18 PM
a 1mm drill bit, driven into the dash face and into the LED would do the trick too
bit of gaffa tape over the light also works, or my favourite take the bulb out!
Posted 02 March 2009 - 08:28 PM
Posted 02 March 2009 - 09:41 PM
Edited by Dynamo, 02 March 2009 - 09:42 PM.
Posted 02 March 2009 - 10:15 PM
Will the airbag still work then? Or just turn the warning off.
Posted 02 March 2009 - 10:37 PM
my understanding is this:
the resistor is to fool the airbag controll module into thinking the seat belts (and their pre-tensioners) are still in place, so the drivers airbag will still work fine.
john
The airbag should still work fine, as the controller will believe the pretensioners are present and correct. I *think* the resistor you need is 7 ohms, but that's from memory so isn't the definitive answer. If you've got a local Maplin, the resistors will just be something like a few pence each.
I need to sort it out on my car, but CBA keeps getting in the way.
Posted 06 March 2009 - 09:28 PM
Posted 07 March 2009 - 09:23 AM
Posted 07 March 2009 - 09:26 AM
Posted 07 March 2009 - 09:28 AM
Posted 07 March 2009 - 02:11 PM
Edited by Nev, 07 March 2009 - 02:13 PM.
Posted 09 March 2009 - 01:21 PM
