Scary Chassis Questions
#161
Posted 06 September 2013 - 01:36 PM
#162
Posted 06 September 2013 - 02:33 PM
Apart from the current situation, the real shitbag in all this is the twat that suffered the damage and covered it up in the first place. Top bloke
I don't think any of us can truly say we know how dangerous this car is, and some of the comments may have been an over-reaction as it isn't just gonna fall apart but, ffs, the current owners are aware and chose not to mention the chasis damage. Not good by any standards, is it?
#163
Posted 06 September 2013 - 09:51 PM
#164
Posted 06 September 2013 - 10:22 PM
The examiner would be perfectly happy with it unless you'd repaired it by welding on the back half of another car.
Edited by JohnTurbo, 06 September 2013 - 10:23 PM.
#165
Posted 07 September 2013 - 07:14 AM
My car is apparently a CAT B. However, it has never had any chassis damage. I had it checked over before buying it as a "Track Slag." It is as straight & clean as they come (around 16k miles from new & only occasionally used for a sunday morning cruise). No doubt, most of the panels are not original...so its a bit like Trigger's broom in that respect.
However, this car is a potential death trap. Breaking it is the way to go. Just make sure you don't accidentally drive it into a tree, that would be so unfortunate!
Max
#166
Posted 07 September 2013 - 07:24 AM
#167
Posted 07 September 2013 - 07:27 AM
just in case anyone has forgotten how bad the chassis damage is
please note the ripped chassis (top left of damage), the deformed upper fuel tank closure panel and the tear where it joined the floor
This is not minor damage, it is severe chassis damage
Edited by vocky, 07 September 2013 - 07:31 AM.
#168
Posted 07 September 2013 - 08:26 AM
VIC website info
The test takes about 20 minutes and is a check of the cars identity, not the quality of its repairs.
However, if the VIC inspector notices a serious defect which would make the car dangerous to drive they may issue a prohibition notice. This means the car cant be driven until its made roadworthy and the prohibition notice is removed.
Personally speaking, I would have thought a ripped chassis would fall into this category. I am simply going by the picture of the car in a previous post.
Trouble is, he wont, you cant see this damage it only came to light after the ears were removed iirc
#169
Posted 04 December 2016 - 07:24 PM
the saga continues, the chassis repair looks well executed but obviously any potential owner needs to get that professionally checked out
before
after welding
Edited by vocky, 04 December 2016 - 07:24 PM.
#170
Posted 04 December 2016 - 09:53 PM
#171
Posted 05 December 2016 - 07:37 AM
at least the current owner was aware of the damage and is pointing out the repair to any potential new owner, this thread started because somebody bought it without knowing the history.
To be fair it would be a perfect track slag, I just hope in the future it doesn't get sold to an unsuspecting buyer - again !
#172
Posted 05 December 2016 - 08:34 AM
#173
Posted 05 December 2016 - 08:43 AM
Bearing in mind you can have a nice high speed accident on track I dont think I'd be happy with that.
#174
Posted 05 December 2016 - 09:07 AM
#175
Posted 05 December 2016 - 09:12 AM
did this end with a happy story.... did the 1st owner end up buy his dream vx....great guy for doing the right thing! hat off to you sir if your still around.
#176
Posted 06 December 2016 - 08:45 AM
To me it looks like it has been repaired with care and consideration, though without actually inspecting it personally (particularly the internal webbing and weld pen) it's hard to be sure. To dismiss it without an objective inspection is what people do when they don't understand that something can be repaired, and repaired well.
People seem to forget that just 25+ years ago people were happily racing cars around that were structurally way weaker than this. Just think of the number of Peugeout 205s, Astra Mk1s, Citroen AX etc etc that used to be ragged around, they crumpled like a paper bag if you hit a wall at 30 MPH. Yet for some reason this car is deemed "binable" by armchair critics even though they haven't inspected it and it is most likely stronger than all those 80s "sports cars".
To think that a critical structure can't sometimes be repaired well is simply wrong, there are umpteen examples of crumbled bridges, bent aeroplanes, subsided buildings, broken lifts, melted space shuttles etc etc, all of which many of us have used in blind and safe ignorance.
Objectivity is required, rather than finger waggling at a couple of pictures.
Edited by Nev, 06 December 2016 - 09:01 AM.
#177
Posted 06 December 2016 - 08:54 AM
you can clearly see in the photo where the chassis glue has been burn't away, which is why they say a vx chassis should never be welded
#178
Posted 06 December 2016 - 08:57 AM
Which bit Vocky? My experience of the glue in these things is that it is quite variable how much each car has oozing out of the gaps, though that is not to say that some of it hasn't been meted.
Edited by Nev, 06 December 2016 - 09:09 AM.
#179
Posted 06 December 2016 - 09:01 AM
The most obvious bit is the V section to the left of the photo - what would be underneath the black side sill
Obviously you cannot see inside the glued chassis section, but the heat required to weld alloy will probably have burn't that too.
But as a track car it should be okay, as a road car probably not
#180
Posted 06 December 2016 - 09:04 AM
Ah yes, I think I see the bit you mean.
Personally I think the vast surface area of the flat surface to flat surface chemical bonds will be stupidly strong anyway, losing a few CM of glue on long spars won't necessarily affect it (if it is only localised melting) IMO, subject to inspection.
I built a complex ocean going boat out of epoxy in the early 90s. I know how strong it is.
Edited by Nev, 06 December 2016 - 09:10 AM.
