Shock / Suspension Fitting Guide
#21
Posted 29 March 2009 - 08:54 PM
#22
Posted 30 March 2009 - 08:37 AM
I will get the wheel off and try to make some more space in the mount.
Mine looks exactly like the following pics too...
#23
Posted 30 March 2009 - 05:39 PM
Nitron sell a revised bracket, tho may be hard to get them to sell it without a shock kitMy MOT test highlighted that there was possible rubbing/touching between the OSF shocker and the upper mount.
Alternatively a gentle tap with a hammer at the lower part (ie below the relief hole) will move it a few mm's
#24
Posted 12 April 2009 - 05:44 PM
Just finished fitting mine, thanks for the 'how to' Adam
But my 'gold's' came with an extra 'locking' adjuster on the height adjustment so even when slightly bending back the mount the shock body fitted fine but when assembled the height could not be fully altered so it was out with the Dremell...
Anyone fitting them save yourself a few hours of swearing and just take about 5mm off each side of the mount, fits perfect then with no touching and plenty of clearance for adjustment
#25
Posted 12 April 2009 - 07:00 PM
#26
Posted 13 April 2009 - 12:32 AM
#27
Posted 13 April 2009 - 11:31 AM
Ahh maybe it's just mine then - I ended up taking about 1mm off the overall width to get them to fit snuglyAll the spacers were the same size but fitted ok with a 'little' persuasion!
#28
Posted 20 August 2009 - 10:26 AM
Standard is like this but I would insert the bolt from the other side.
#29
Posted 24 August 2009 - 08:00 PM
Oh and the carpet is an old bit from my mums for the garage.
Steve.
#30
Posted 24 August 2009 - 08:19 PM
#31
Posted 25 August 2009 - 07:54 AM
Thanks Mandarin for the guide - as I have fitted my gaz gold today. I would have never tried it without. Here are some pictures of my adventure.
Steve.
What spring rates did you go for?
P.S. what is the cutout / mesh in the liner for?
#32
Posted 25 August 2009 - 09:19 AM
#33
Posted 25 August 2009 - 04:12 PM
I have gone for 425 front and 550 rear. Behind the mesh is a 13 row thermostate controlled oil cooler.
Steve.
I'd be interested to know how you get on with those spring rates. 550 for the rears seems stiff!
#34
Posted 25 August 2009 - 08:03 PM
imo it's a bit much, I'll be changing back to 500 shortlyI'd be interested to know how you get on with those spring rates. 550 for the rears seems stiff!
#35
Posted 25 August 2009 - 08:16 PM
#36
Posted 26 August 2009 - 09:57 AM
Steve.
Don't forget I have a turbo, which as you now weighs a little more than an na
I love this site, without it I would have never had the balls to fit the gaz's (thanks to mandarin
Thanks again
Steve.
Edited by Whiteboy, 26 August 2009 - 10:06 AM.
#37
Posted 26 August 2009 - 10:09 AM
Steve.
I would love to see T20 again.
Steve.
#38
Posted 26 August 2009 - 05:56 PM
Steve.
I would love to see T20 again.Would you be interested in a meet after I have had the geo done and you could see for yourself how good/bad the set up is for your needs.
Steve.
Yeah definately up for a meet.
P.S. Do you have to be called Steve to have a Moonland
Steve
#39
Posted 26 August 2009 - 08:58 PM
#40
Posted 26 August 2009 - 09:15 PM
Just finished fitting mine, thanks for the 'how to' Adam![]()
Anyone fitting them save yourself a few hours of swearing and just take about 5mm off each side of the mount, fits perfect then with no touching and plenty of clearance for adjustment![]()
Sorry Mr Simba, I'm struggling to understand what needs trimming off of where!? Could you help me out please (preferably with pictures) as will be fitting my golds soon. Cheers
