New Chris Tullett Exhausts
555 replies to this topic
#41 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 28 March 2009 - 09:24 PM
According to Wiki,
Aluminium will melt at 660 degrees C
The video on CMS's website shows that the manifold will glow red
The temp this happens to stainless according to Wiki is 580 for visible in daylight, and dark red is >700 degrees C :o
Won't cracking be more of an issue as opposed to melting?
#42 MAXR
MAXR
  • 2,719 posts
Posted 29 March 2009 - 08:39 AM
These are a few of my 2ubular 3" system...
Secondary Silencer...There's room to increase the size of the first silencer substantially on mine, which I may have to do...
Nick,
I will let you know how good the modified 2-11 rear box performs.
Paul,
The heat generated by my S/C exhaust has melted away the clam around the exhaust tip & bubbled the paint above the exhaust tips & that's with only 250 horses...
I did wrap my manifold, but that just transferred a more intense heat further down the exhaust, but have since removed it to try and allow some cooling to take place in the engine bay area as my car has had the boot bulkhead & major holes cut into the rear. It also has no silencer heat shroud & I am also not running with any plastic wheel arch liners....I know when I upgrade to the Harrop & my new Vocky fettled engine, it will be a challenge to remain reasonably quiet & to allow enough cool air through the bay. I will probably have to incorporate some enlarged air ducts in the undertray. I have gone for a single exhaust tip as I now have a supertrap to bolt on to my single (un rolled exhaust tip, which I requested) as a final measure if required. I've not had to resort to it as yet!
#43 techieboy
Posted 29 March 2009 - 09:08 AM
Well, it's probably safe to say that I was the second loudest car on the track over the weekend with my hybrid/development Piper system. Luckily it was France, so they weren't bothered. But pretty sure I'd have had no chance on a UK track, unless it was a 105dB/test day. :( Sounded epic in a couple of tunnels on the autoroute and the Dartford tunnel though. :D
Edited by techieboy, 29 March 2009 - 09:09 AM.
#44 Winstar
Winstar
  • 4,264 posts
Posted 29 March 2009 - 12:28 PM
According to Wiki,
It'll never melt as it's the pump return pipe.
#45 The Batman
Posted 29 March 2009 - 02:24 PM
great....
#46 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 29 March 2009 - 03:33 PM
great....
Looks like I might be better off just asking for a refund :unsure:
#47 Muncher
Muncher
  • 4,494 posts
Posted 29 March 2009 - 03:35 PM
Have put a few more miles on it today, it has quietened a little. There is quite a large variation under load/not under load. I would guestimate it would have no trouble passing any static tests.
#48 The Batman
Posted 29 March 2009 - 03:41 PM
well a 26" by 7" silencer with a 6" silencer next to the cat, doesnt silence the charger then we indeed have a problem!
#49 SteveM
SteveM
  • 1,608 posts
Posted 29 March 2009 - 03:42 PM
Could you explain what the benefits of the 3" system and manifold on a s/c car are over a Milltek 2.25" exhaust with OEM manifold. Is it just more power? Mine is running around 245bhp with the Milltek and OEM manifold. cheers Steve
#50 The Batman
Posted 29 March 2009 - 03:46 PM
yup but remember if you exceed 250bhp you should really change the rods
#51 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 29 March 2009 - 03:50 PM
cheers
Steve
The 3 inch is really for those who want to allow for going over 300 bhp up to about 400bhp The limit of the miltek as about what you are running now it chokes over that, If you just replace the manifold and exhaust system you will get about another 20-30 bhp. techieboy would run 270 if I remember with the piper. I would imagine a straight through 2.5 should be good up to say 270ish
#52 The Batman
Posted 29 March 2009 - 03:52 PM
im running 270 and thats with the vocky head and piper cams and piper full exhaust
#53 NickB787
NickB787
  • 7,813 posts
Posted 29 March 2009 - 04:00 PM
Just found Techieboys post and 262bhp he made with a 4-1(JT) not certain about the cams.
#54 The Batman
Posted 29 March 2009 - 04:02 PM
that 4-1 is very pretty :wub:
#55 NickB787
NickB787
  • 7,813 posts
Posted 29 March 2009 - 04:07 PM
Yea looks the biz but ££££
#56 The Batman
Posted 29 March 2009 - 04:08 PM
indeed and probably why he didnt shift many!
#57 Muncher
Muncher
  • 4,494 posts
Posted 29 March 2009 - 04:30 PM
Chris's own version of that is just under £500 Inc VAT and he says it will perform just as well.
#58 The Batman
Posted 29 March 2009 - 04:37 PM
always best if possible to get read outs before and after fitted thumbsup
#59 slindborg
Posted 29 March 2009 - 08:28 PM
you mean 220bhp at the fly then :P
Paul if you buy one of those sound meters from Maplins, be VERY wary of the results as they have a +/- 3db tollerance lol
#60 mandarinvx
mandarinvx
  • 12,621 posts
Posted 29 March 2009 - 08:41 PM
Nahhh It's only +/- 1.5dB :P
Don't a lot of track organisers use the same type of thing :unsure:
