New Chris Tullett Exhausts
555 replies to this topic
#101 Muncher
Muncher
  • 4,494 posts
Posted 10 April 2009 - 09:56 PM
Both readings were 96dB
He's now extending the silencer by about 5 inches, so up to ~32 inches long
if it is 96db now, why is he adding an extra 5"s?
As a safety margin, remember I am also only running ~220bhp at the moment but with the LSJ engine will be running 375bhp+ which will make it a lot louder.
#102 The Batman
Posted 10 April 2009 - 09:57 PM
thumbsup and 375 Imnotworthy
#103 alanoo
alanoo
  • 1,324 posts
Posted 11 April 2009 - 09:02 AM
I guess the delay for a 4/2/1 will be too long unfortunately... :unsure:
I'll ask Chris but I wouldn't have thought it'd be too long, maybe a week or two?
Well why not...
I'll have to have it adapted to my 2bular cat next, but I could have this done locally by our welder
The 4/1 would be plug and play on my 2bular cat section but of course still not optimal at all on my N/A build :glare:
#104 Muncher
Muncher
  • 4,494 posts
Posted 11 April 2009 - 11:48 AM
Well why not...
So you'd want a 4-2-1 which would have a similar flange position to my 4-1 on my 3" system, i.e. further down to the primaries are longer?
#105 alanoo
alanoo
  • 1,324 posts
Posted 14 April 2009 - 08:23 AM
To make a good 4/2/1 you'll have to have a flange close to the cat I don't really care, I just need at least an interim solution, I noticed the plug&play OE flanged position 4/1 has unequal lengths btw, cyl 2 appox 3.5cm shorter, not sure at all something better is doable but if this proto is for sale at a good price, I may be interested :closedeyes:
#106 Muncher
Muncher
  • 4,494 posts
Posted 14 April 2009 - 09:44 AM
It's probablky easier if you give him a call on 01296 483777 and have a chat with Chris :)
#107 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Got measured at Snetts yesterday at 5200rpm it was about 94, about because I wasn't a steady as I should have been :rolleyes: good though I am pleased. Off to Bedford to check it there.
#108 Muncher
Muncher
  • 4,494 posts
Posted 14 April 2009 - 09:56 AM
That's good. I don't think mine gets much louder past 4,500rpm actually.
#109 Muncher
Muncher
  • 4,494 posts
Posted 16 April 2009 - 06:47 PM
Picking it up tomorrow, it's been made repackable and the silencer has been extended by 4 inches. No packing had been lost since it was built and the heat colouration suggests it's not getting too hot leading to a breakdown in packing, which is a good sign.
#110 The Batman
Posted 16 April 2009 - 06:48 PM
when will you be running 375? as once this is done then get a sound tested as me and probably many others will be wanting this information!
#111 Muncher
Muncher
  • 4,494 posts
Posted 16 April 2009 - 08:18 PM
Once I can get the new engine built. I have every part aside from the pistons, new injectors and the fuel pump arrangement, plus a few odd bolts etc. The Harrop and my porting kit will be with me next week so I can start working on the head, the endplate is coming off so Pro Alloy can do the dual pass mod to it, adjust the oil filter housing on the LSJ block and plug a couple of oil paths in the head. Anything over 350bhp I will be happy with really. Being realistic I think we are looking at Autumn time perhaps.
#112 techieboy
Posted 16 April 2009 - 09:30 PM
What injectors do you need Muncher? I've got an almost brand new set of LSJ (green) injectors that have only seen some action on a dyno whilst TMS were trying to remap for them as part of the 2.4 inlet conversion.
#113 The Batman
i have 2 lsj injectors that are brand new :lol:
#114 Muncher
Muncher
  • 4,494 posts
Posted 16 April 2009 - 09:40 PM
Not sure, I will check. I think they're Bosch ones, possibly the VXR ones?
#115 alanoo
alanoo
  • 1,324 posts
Posted 17 April 2009 - 08:47 AM
I think he'll need some bigger stuff than LSJ injectors ;)
#116 Muncher
Muncher
  • 4,494 posts
Posted 17 April 2009 - 06:28 PM
I have it back now, with an extra 4 inches :) It is certainly quieter, noticeably so, I'd say it was just perfect now. 3,000 rpm = 89dB 3,500 rpm = 91dB 4,000 rpm = 91dB 4,500 rpm = 92.4dB 5,000 rpm = 95.5dB 5,250rpm = 96dB Very pleased :)
#117 The Batman
Posted 17 April 2009 - 06:29 PM
oooo only leaving a couple of dbs for an extra 150bhp :o
#118 Muncher
Muncher
  • 4,494 posts
Posted 17 April 2009 - 06:39 PM
More than a couple, with a 105db limit @ 4,000rpm that's a whole 14db off. Plus I don't think the volume will alter THAT much with the extra power, it's more about resonance and tone at various rpm rather than volume of gas I think.
#119 The Batman
Posted 17 April 2009 - 06:46 PM
bedford has a db limit off 98db at 3/4 revs thats what most places test at as this is the peak loudest otherwise they wouldnt test at this!
i imagine that an extra 150bhp would make a fair bit more noise but i dunno im no specialist!
#120 Muncher
Muncher
  • 4,494 posts
Posted 17 April 2009 - 07:14 PM
How do they determine the rev limit? It will quieten slighly if anything as it beds in. It is also repackable so more stuffing can be added as required.
