Rub A Dub Dub
#221
Posted 21 May 2010 - 04:18 PM
#222
Posted 21 May 2010 - 05:07 PM
Yeah, the ever-delayed May meet at this rate!Wooohooo. There's a man who sounds like he might make a Beds/Bucks meet before the summer is out.
Glad you're getting to the stage where it's just the annoying little bits that need doing.
A frustratingly long list of annoying little bits. And the chasing after the wrong parts doesn't help.
#223
Posted 21 May 2010 - 05:44 PM
#224
Posted 21 May 2010 - 05:54 PM
It's going on a Q-plate so not worrying about those stickers at least for now. The first thing that comes to mind thoough is that really strong but thin and clear double-sided tape.Out of intrest what are you useing to stick the paint code label thingy to the drivers sill?
#225
Posted 27 May 2010 - 10:27 AM
As you can see the tires are off to be mounted. The last batch of fibreglass parts goes off to the paint booth tomorrow. However, the fibreglass is badly cracked where the bonnet pin mounts to the bonnet. Is this normal?
I finally got the oil filter cover loose the other day, with a cheater pipe and a large prybar. Of course the gaskets for the oil cooler sandwich plate are VX specific so I can't get them at the local stealer.
Got some little O-rings for the bleed screws, and 7L of coolant, so at least I can get that finished. Main thing I need to concentrate on now is the suspension. That is the biggest thing that needs to be done before the clams go on.
#226
Posted 27 May 2010 - 11:22 AM
#227
Posted 27 May 2010 - 11:55 AM
#228
Posted 27 May 2010 - 12:33 PM
Are you blocking me?I bought the complete bonnet pin assembly components for a quite reasonable £20 from the dealer several years ago, but lotus will be cheaper
as for the size of the mafiamobile's boot
Cheers. Good thought going to Lotus. However, I can't get the oil cooler sandwich plate gaskets from them so it will probbaly be easier to just order it all from Autovaux. Speaking of which, my new coolant cap was $15 trade from the stealer!
#229
Posted 27 May 2010 - 12:35 PM
#230
Posted 27 May 2010 - 02:09 PM
it's the stupid site PM systemAre you blocking me?
You replied to my post but not my pm.
I tidy up the conversations in my PM inbox every few weeks, but if someone then sends a reply I don't get the message
#231
Posted 27 May 2010 - 02:10 PM
#232
Posted 27 May 2010 - 02:13 PM
#233
Posted 20 June 2010 - 04:56 PM
#234
Posted 20 June 2010 - 05:03 PM
I believe there is an update due with some pics
Is the bodywork on?????
#235
Posted 20 June 2010 - 06:12 PM
You can also see that all of the new wheels are on. What is significant about this is that the new wheels were put on as the Sachs coilovers were installed, new HCBs, and the wishbone bushes tightened up. Vocky also got the caster shims in, so the suspension is done!
The splodge is still setting on the rear mesh. Another thing that Vocky did a great job on.
#236
Posted 20 June 2010 - 08:17 PM
#237
Posted 20 June 2010 - 08:25 PM
You would think that would make it easier to find bits in the pile at this stage.not much more left to fit now
#238
Posted 25 June 2010 - 12:10 AM
#239
Posted 26 June 2010 - 10:20 AM
Hmmm. Thanks, but I think that I'll keep them for now.I see you have black centre caps with the wheels. I have black TDs with silver centre caps so if you fancy a swap I would be happy
They do 2 versions of the black ones at least. Black with black stickers in the centre, and black with silver stickers. Or is that what you mean by silver ones?
#240
Posted 02 July 2010 - 01:39 PM
