Rub A Dub Dub
427 replies to this topic
#81 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 06 December 2009 - 07:12 PM
A big thanks to Duncan VXR for putting humpty dumpty back together with tigerseal (heater box). It is now bolted down and plumbed in. chinky chinky
A HUGE thanks to Vocky for coming by with a BIG disc cutter and helping to separate the old tub for metal and plastic recycling bins. thumbsup
We recovered pretty much everything off of the old tub. Only things left on it are the rear window and the top of the pedal box. Take those off and haul it to the scrapyard next.
I do have the crashbox off the old tub finally, well with 6" of the old tub still attached. :rolleyes:
#82 rsg
rsg
  • 3,306 posts
Posted 06 December 2009 - 07:26 PM
Glad your making good progress chinky chinky Is the tub worth anything in scrap Ali??
#83 vocky
Posted 06 December 2009 - 07:30 PM
you are on the 'home run' now, just the interior, suspension and body panels to go :D
#84 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 06 December 2009 - 07:37 PM
Cheers. Considering that 2 of us still can't carry it, it ought to be worth a bit. :blink:
Yeah, only half a million things to do now. :rolleyes: Big one is still going to be the crash box. :angry2:
#85 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 04 January 2010 - 09:29 PM
Well, no progress to report. However, I am thinking that it is time to get the bodywork done so that I have a chance of getting it on the road by the end of spring. Since I have not been able to find any colours that I prefer, it looks like it is going to stay Calypso. That also means that the next step is prepping the bodywork for the paint shop. There is a little to do on the clams, but the main bits will be sorting out the roll bar cover, doors and mirrors. They are going to do some repairs to the fiberglass, but everything has been indoors and dry for 15 months so hopefully in good shape to be repainted without much risk of bubbling. Maybe I should repaint all of the grills before they repaint all of the fiberglass, or should I do it after? :unsure:
#86 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 04 January 2010 - 09:42 PM
I would give it a good paint prior Theo - you will be able to give it some good coats from either side ;) - could always give it a final coat when back as it does not take long :) Hope the bag did not smudge the tiger seal too much as it was still a bit wet when you collected it :( Trust Ian to get all the fun with the BIG blade lol Time to get serious and get it done while you are allowed to play out :D DG
#87 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 04 January 2010 - 09:50 PM
Trust Neil to get all the fun with the BIG blade lol
DG
Good point. Probably worth going over it with a wire brush too.
Not bothered about the tiger seal. Took it out of the bag, and dumped it in the car. thumbsup
Yes, Neil did seem to enjoy himself. We were both impressed with the amount of metal that had to be cut! :blink:
#88 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 10 January 2010 - 07:28 PM
Well, a bit more progress today. Borrowed a plasma cutter and got most of the big chunks of metal off of the back of the crash box. A bit more work and it will be down to not much more than the actual metal that the crash box is bonded to. Hopefully it will be easier to cut off then. :angry2: I also took the rear window and then the rear bulkhead off of the old tub. It is now ready for the metal recyclers. Will have to take it at luch someday. Any guesses how much money I'll get for it? :rolleyes: I also started preparing the body parts for paint. They will do the final prep, but I am taking off lights and trim and whatever else will easily come off. There is a bit of cleaning off tiger seal as well. Hopefully I can get that all done next weekend, I want the stuff to go to the body shop soon after.
#89 The Batman
Posted 10 January 2010 - 07:30 PM
dont suppose you know how heavy the rear window is do you?!
#90 techieboy
Posted 10 January 2010 - 07:56 PM
Vocky probably knows as he replaced MaxR's with a poly version, didn't he?
#91 rsg
rsg
  • 3,306 posts
Posted 10 January 2010 - 08:01 PM
I can remember him saying there wasn't a massive weight loss in the rear screen, but the door glass weighs loads
#92 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 10 January 2010 - 08:12 PM
Well done Theo, sorry I could not make time to help today :( But did get a few thingsdone on mine before dinner at my mums :D no work possible after that lol
#93 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 10 January 2010 - 08:14 PM
It doesn't weigh a lot.
#94 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 12 January 2010 - 08:54 PM
I think that I've decided what to do with my spare passenger side heater pipe that runs down the sill - use it as a hard line for the brake servo hose :P :D
#95 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 18 January 2010 - 09:32 AM
OK, another big thanks to DuncanVXR! thumbsup This time for using up a really nice afternoon on my car instead of his. I see myself under his helping do rods in the near future. :rolleyes: We got a lot of work done on the fiberglass bits to prepare them for the paint shop. The rool bar cover and front clam are ready. The rear clam and the one side sill that I am re-using are almost ready. Duncan did forget to take the engine cover prop rod and the rear light clusters out of the rear clam though. :P While we had the angle grinder out opening the brackets behind the rear wheel well liners I also separated the exhaust at the 3-bolt flange (it was taken off in 1 piece). Now I can put the downpipe back on and reconnect the lambdas. Add the binnacle and a battery and it would probably start. I am thinking of sending the doors, bonnet, and engine cover to the paint shop as a second batch later. The replacement door that I got needs a little work, but the rest of those parts are in excellent condition. They also bolt on easily at the end, and I don't want stuff laying around too long after paint and getting damaged. The paint shop says that it won't be an issue for matching. I do want to fit the Leon splitter before the front clam goes to paint, and I am thinking of doing the window surround and the mirrors in anthracite after seeing pics of AliM's car. chinky chinky
#96 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 18 January 2010 - 10:19 AM
Never forgot just getting home on time for once to stop myself getting into more trouble :D Like how my brain washing of helping me do my rods / cams etc is going LOL Some real PITA screws and bolts yesterday to remove and it does seem the little jobs take the most time :o Great idea on the hard pipe Theo ;) shpould make any further fixes on the hose V easy And do like teh plan for the colour scheme - very 2-11 :D DG
#97 The Batman
Posted 22 January 2010 - 06:36 PM
how much did you get for the ali tub then?!
#98 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 22 January 2010 - 09:16 PM
I haven't had a chance to run it over yet. I am toying with the idea of taking it to the diygarages day and getting someone to show me how to replace it. :lol:
#99 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 31 January 2010 - 08:49 AM
Here is a pic of the tub ready for the scrapyard. I have been using the plasmacutter to whittle away at the metal still on the crashbox. I have been doing it in the tub in a vain attempt to control the mess. :rolleyes:
#100 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 31 January 2010 - 11:09 AM
Should give you a good few quid. We sell quite a bit of scrap metal at the yards for our tea boat. We change about 5 vehicle batterys a week and that gets us around £25. Last time though i took down a cracked ally head from an escort and to my supprise they took it. Even still had some steel bolts in that i couldnt get out. Weighed it down a little :)
