Rub A Dub Dub
#121
Posted 20 February 2010 - 05:08 PM
#122
Posted 20 February 2010 - 05:20 PM
It is a slippery slope. I had to hold back almost completely or it would have never gotten done for want of time and money. I spent enough time sorting out rusted fasteners as it was. Just 10 mintues ago finished putting hammerite on the bracket and bits for the bonnet latch so that those can all go back in tomorrow. Going to have to order all plated or stainless fittings for the undertrays, etc.i dunno how you did it without modding every little bit!
That said, I plan to get GAZ Pros and have a proper alignment done. I may also get TD 1.2 wheels and Kumhos. Now that the stock exhaust is on I doubt that I will do anything about that, at least for a while. I also got Mr Simba's radio and will probably do speakers..
Next winter I hope to do homebrew ITBs and build a Megasquirt to run them.
#123
Posted 20 February 2010 - 05:23 PM
#124
Posted 20 February 2010 - 05:26 PM
On 2-year old petrol!It was good to hear it running, sounded very sweet for an engine which hasn't run for almost two years
#125
Posted 20 February 2010 - 05:28 PM
#126
Posted 20 February 2010 - 05:32 PM
#128
Posted 20 February 2010 - 08:56 PM
#129
Posted 20 February 2010 - 09:53 PM
#130
Posted 21 February 2010 - 10:02 AM
I'm taking donations.you could have changed the header tank
Yeah, Vocky berated me for that too.
Am I the only one that thinks that it looks like Luke Skywalker's land speeder thingie in that photo? Now that it has the exhaust and no suspension?
#131
Posted 21 February 2010 - 12:09 PM
Yeah looks good haha
Its picking up speed very nicely now
#132
Posted 21 February 2010 - 07:49 PM
For future reference, the rear jacking point was the center of gravity and putting the rear suspension on first made it tip back.
The suspension is only on loosely, and no castor shims. Need more parts on the car and it to be sitting on the ground to tighten everything up. I will probably let Guglielmi's do all of that when they do the geo at the end.
Yes, I am going to replace the front discs! Also, the rear toe links are worse than I thought. I may have to go for the EP kit.
I also finally got the shear panel under the fuel tank torqued down. The rivnuts on that were a pain! Plenty of other little things done today too, they sure add up though in terms of time.
Didn't get the shifter cables in, plan to do that this week. Won't be much more in the way of visible changes for a while now. Also, I remembered some foam blocks that go under the corners of the windscreen behind the sills. I need to sort those out before I put the sills on.
Edited by theolodian, 21 February 2010 - 07:52 PM.
#133
Posted 21 February 2010 - 07:54 PM
Edited by vocky, 21 February 2010 - 07:55 PM.
#134
Posted 21 February 2010 - 08:01 PM
Cheers!it's really coming along now
soon be time to bleed the brakes and clutch
ps: wheres the front anti roll bar
Yeah, well my arms were dead after doing all 4 corners in an hour! They're heavy and to boot the bloody lower rear wishbones really didn't want to go in. Much use of the pursuader was required.
#135
Posted 21 February 2010 - 08:18 PM
Wait until the caster shims
looking good Theo
#136
Posted 21 February 2010 - 08:23 PM
That's why I'll probably let Guglielmi's do them. Caster is part of the geo isn't it?Wait until the caster shims
looking good Theo. If you need a closer look at any cable routing (or anything else for that matter), I'm back in Leamington from Thursday till the end of the weekend. Pop round and take a peak on mine
Cheers. I'm off to the Med on Thursday so maybe next time.
#137
Posted 22 February 2010 - 10:02 AM
#138
Posted 22 February 2010 - 01:02 PM
#139
Posted 22 February 2010 - 01:21 PM
#140
Posted 22 February 2010 - 09:40 PM
