These are axial mount, is there other parts bin stuff to rob for the radial mounts
Mgtf 4 Pot Caliper
Posted 22 April 2009 - 11:00 AM
Posted 22 April 2009 - 12:02 PM
Has anyone else tried the MGTF 4 pot calipers with the rear handbrake setup as well
MEAGY is running that setup, and I think Vocky has some further info...
Posted 22 April 2009 - 12:32 PM
Posted 22 April 2009 - 12:37 PM
Posted 22 April 2009 - 03:15 PM
Posted 22 April 2009 - 03:35 PM
How do these, or other 4-pots, affect the brake balance? I hear that the bias is too much to the front with stock brakes. I wouldn't want to make that worse.I fitted a brand new pair on the front of mine
the guy at the MOT station said he had never seen a car with 90% brake efficiency on the front before, the usual is about 60%
Posted 22 April 2009 - 04:46 PM
You should get that dual caliper set up on the rear, and a neck brace so your head does not get ripped off.
Posted 22 April 2009 - 09:19 PM
and are radiel mounted
Edited by leevx2.2, 22 April 2009 - 09:24 PM.
Posted 22 April 2009 - 09:33 PM
chap, spill the bean - these are axial mounted. Totally NOT plug and play.Go on ebay put in{ mg big brake} and you will see the calipers i used brand new discs and calipers £499
and are radiel mounted![]()
Brackets need to be milled so spill the beans on who/where/how eh?
S10 YHM
Posted 22 April 2009 - 09:41 PM
Edited by leevx2.2, 22 April 2009 - 09:43 PM.
Posted 23 April 2009 - 06:14 AM
Posted 23 April 2009 - 08:10 AM
Posted 23 April 2009 - 09:04 AM
Posted 23 April 2009 - 09:10 AM
went in snetterton with higgings (doesnt post on there very often) conversion and must admit the breaking wasHoffmans do not think there is any need to change calipers front / rear. Just better pads & discs
Be interesting to actually get some testing done between differnet brake setups but sure different weights of cars and suspenson will also play its part in the results
Posted 23 April 2009 - 11:35 AM
Posted 23 April 2009 - 06:22 PM
the mgtf calipers require a skilled machinist to adapt them, then they require mounting brackets and new hoses.
they are not a simple bolt on
Haha you can say that again, just got mine fitted with sbs pads & now they are bedded in i can do an endo very easily
just need better pads at the rear now.....oh....actually i dont as i should have the 2 pots on the rear next week
Posted 23 April 2009 - 06:23 PM
Haha you can say that again, just got mine fitted with sbs pads & now they are bedded in i can do an endo very easily![]()
They worked out ok did they Liam? Do they have MG stamped on them, or do they say AP?
Posted 23 April 2009 - 06:27 PM
Posted 23 April 2009 - 06:29 PM
mg...but a 9" grinder got rid of that lol
Posted 23 April 2009 - 06:32 PM
Bing (1)
