that first picture has mg on it
its magic joe....
Posted 23 April 2009 - 06:33 PM
Posted 23 April 2009 - 06:56 PM
any pictures of bracket and measurments or someone that van make these brackets?
Posted 23 April 2009 - 06:58 PM
its magic joe....
Posted 23 April 2009 - 06:59 PM
Posted 23 April 2009 - 07:05 PM
Posted 23 April 2009 - 07:19 PM
Posted 23 April 2009 - 07:29 PM
Edited by robin, 23 April 2009 - 07:29 PM.
Posted 23 April 2009 - 07:58 PM
Edited by vocky, 23 April 2009 - 07:59 PM.
Posted 23 April 2009 - 08:08 PM
Posted 23 April 2009 - 08:59 PM
My only suggestion would be to chop a great big hole out of the center, say 80x20mm with round ends. Save a little weight.
Posted 23 April 2009 - 09:19 PM
the calipers also require machining, a good machinist will be able to do that
I paid about £50 for both calipers to be machined
Posted 24 April 2009 - 01:11 AM
It is steel, and the half-circle ends are very important. That part of the plate is only being used as a shear web. The half-circle ends will leave enough reinforcement of the corners, which otherwise would be the weak point. Of course the last thing that you want is sharp inside corners . . .My only suggestion would be to chop a great big hole out of the center, say 80x20mm with round ends. Save a little weight.
Take it from me that would be a very bad idea, that piece of 10mm plate will be highly stressed as it is a hole that big in the middle will prob cause it to fail pretty quickly.
Posted 24 April 2009 - 06:33 AM
Edited by vocky, 24 April 2009 - 06:36 AM.
Posted 24 April 2009 - 08:07 AM
Posted 24 April 2009 - 06:38 PM
Posted 24 April 2009 - 06:56 PM
Posted 01 May 2013 - 09:21 PM
Posted 01 May 2013 - 09:55 PM
Posted 01 May 2013 - 09:59 PM
