Had a play with them today, they stop well. My rear pads are currently pants though so need that sorting.
(My rear yellows are due to arrive on Monday)
I also miss the over servo'd feel of the hispec/ftr setup - it really stopped very well, but this should be better for last second braking on the track.
+ If i'd bought RC6 pads I'd get the over sevo'd feel back!
I de-MG'd them, and hit them with Red hammerite which is in your face, but looks good with the wheels on.
Starlight,
After removing the pads, pins and middle cross bolts:-
1) Bandsaw off the bracket roughly.
2) Face the caliper off until the 'bracket' just cleans off - a web just disappears before its time to stop. If i remember I'll get a measurement top to bottom.
3) Pick up the centre of the caliper...bore 2x 10mm holes 150mm apart, even about the radial centre line and 27.5mm offset from the centre axially.
4) Add very shallow counter bores to the tops of the caliper for the heads of the capheads. - Buy 85mm M10 capheads for attachment to hub,
5) Pad seats need to be ground clear a little with an angle griner/dremel.
6) Drill the crossbolt holes through to 10mm, add counterbores in the miller.
7) Drill to 10.5mm just upto the radial mounting holes, tap for helicoils and add helicoils from the outside. Reuse original crossbolts.
Thats the lot. Banjo type hoses needed - available from EP.
