Chris Tullett Exhausts - Group Buy On 2.2 Systems
94 replies to this topic
#41 savvy
savvy
  • 2,524 posts
Posted 15 May 2009 - 07:32 PM
Picked up my 2.5" system this afternoon :rolleyes: - a very nice piece of quality work and re-packable too thumbsup
how long did it take to from order to collection? not that i'm in a hurry :lol:
#42 chris_uk
Posted 16 May 2009 - 09:11 AM
oh and do you need to modify anything to fit the equal length manifold? i assume the piper 2.5 system will join onto the bottom of it no problem?
#43 Muncher
Muncher
  • 4,494 posts
Posted 16 May 2009 - 09:18 AM
Nothing needs to be modified to make it fit. The standard headshield won't fit on but I took the opportunity to replace the foam heatshield on the bulkhead with soime proper bolt on nimbus stuff instead.
#44 chris_uk
Posted 16 May 2009 - 09:47 AM
so will it make much difference if i swapped it from the piper 4-1?
#45 Muncher
Muncher
  • 4,494 posts
Posted 16 May 2009 - 11:08 AM
I would hazard a guess at 5-6bhp extra.
#46 chris_uk
Posted 16 May 2009 - 01:34 PM
oh really.. i might have to sell this one that i have then..
#47 patje
patje
  • 1 posts
Posted 17 May 2009 - 10:42 AM
Is it possible to get a 200 cell kat in sted of a 100 cell. Because MOT is difficult tto pass in Belgium.
#48 Muncher
Muncher
  • 4,494 posts
Posted 17 May 2009 - 10:51 AM
That shouldn't be a problem.
#49 myhifi
myhifi
  • 62 posts
Posted 19 May 2009 - 06:57 AM
Hello,
I have contacted Chris Tullet and 200 Cell is possible.
Futhermore, there is a new silencer now. It is longer and fully repackable as standard. Price has moved up a little, call them they are great.
Awaiting my invoice now...
#50 robin
robin
  • 3,810 posts
Posted 19 May 2009 - 07:20 AM
out of intrest i got a piper system 2.5" which was told if i went supercharging would be fine, is this the case or would a 3" be the best system for this?
#51 Muncher
Muncher
  • 4,494 posts
Posted 19 May 2009 - 10:01 AM
3" is best for 250bhp+ Your main concerns will be will the packing stay in the Piper one and it also being too loud when supercharged.
#52 alanoo
alanoo
  • 1,324 posts
Posted 30 May 2009 - 11:56 AM
Ok, received my 4/1 "SC" version last week but only opened it today : 1. When I took the closed box, my first thought was "Oh my god, WTF !" The box was simply TOO light to have a manifold in it... but it did. Seriously that thing is really light 2. Quality is superb 3. Lines up perfectly with one of my spare LSJ head, with a bit of margin for some exhaust ports porting. 4. Why, oh why, has it an EGR port :ninja: I'll try to take some pics for all of you a bit later :)
#53 alanoo
alanoo
  • 1,324 posts
Posted 30 May 2009 - 05:25 PM
Ok, actually I spent about 6 hours adjusting the flange holes, bit tired and costed a lot on Dremel stuff...
#54 Muncher
Muncher
  • 4,494 posts
Posted 30 May 2009 - 06:16 PM
My one doesn't have an EGR slot... What adjusting did you do?
#55 alanoo
alanoo
  • 1,324 posts
Posted 30 May 2009 - 06:41 PM
The hole just below the EGR is off Other ones are tight, but this is cool as it gives an almost perfect centering The rest was specific to me as my -1.4mm head get some clearance issue at the lowest level of the flange had to remove 1mm at both lowest extremeties of the flange due to it getting the block on its way But seriously, the EGR is a bad surprise, why on a stuff meant to SC... bad bad bad :groupjump:
#56 PaulCP
PaulCP
  • 6,066 posts
Posted 01 June 2009 - 09:28 AM
Just got back from 10 days away in the Middle East so now need to get mine finished. Just need to get the clam back on. I have already reported to Chris about the holes being out of line so he is aware of the problem Paul, hopefully i will have those brackets for you later in the week
#57 PaulCP
PaulCP
  • 6,066 posts
Posted 08 June 2009 - 02:02 PM
Finally got my 2.5" system fitted. Car is at Courtenays at the moment so that the mapping can be adjusted but initial thoughts 1. Seems to rev easier & not as much SC whine 2. Not as noisy as Munchers 3" system 3. Pretty quiet on cruise 4. A bit more boomy than the Milltek system when accelerating hard but not uncomfortably noisy inside the car with roof on Will try to get some Db tests done asap & atthe moment no lambda problems with the 100cel cat
#58 Dominique
Dominique
  • 138 posts
Posted 01 July 2009 - 08:49 PM
We've spend an evening puzzling to get the 2,5" manifold in without removing the clam. Has anyone managed to install it while leaving the rear clam on?? We've tried tilting the engine to gain space with the two lower engine mounts loose, but the centre line of rotation is too high to make this work. any suggestions?
#59 PaulCP
PaulCP
  • 6,066 posts
Posted 02 July 2009 - 09:13 AM
any suggestions?
Unfortunately i had other things to do so i took the clam off which made getting the manifold & system on pretty easy.
I've since tightened my manifold bolts so you can get to them easy enough.
A couple of suggestions
1. do you have the original heat shield material lining the boot area on. You can get more room by taking it off
2. It may also be easier to take out the bolts from the head, offer the manifold to the head then put the bolts back in. This will give you a bit more room.
make sure taht the holes in the flange mate up to the head though. The end one's on mine needed elongating to get it to fit.
#60 rsg
rsg
  • 3,306 posts
Posted 02 July 2009 - 11:36 AM
any suggestions?
Yep I did it, can't really say how because it took feckin ages and part of that required use of a rubber mallet. Not easy but just about do-able
