Sc'd Vx Smells Of Oil/fuel Under Acceleration
Posted 04 May 2009 - 07:54 AM
Posted 04 May 2009 - 08:04 AM
Posted 04 May 2009 - 08:09 AM
Posted 04 May 2009 - 09:10 AM
Posted 04 May 2009 - 09:55 AM
Posted 04 May 2009 - 10:09 AM
Posted 04 May 2009 - 10:21 AM
I have the same issue, the smell can be quite strong. Can we have a show of hands of who has modified the gasket and who has the smell?
did you ever remember what courtenays said the reason was?
Posted 04 May 2009 - 10:24 AM
Posted 04 May 2009 - 11:18 AM
Posted 04 May 2009 - 11:23 AM
Would be interested as to why Courtney don't do this.
Yeah, I'd be interested to know why, as well. Maybe they just don't want any cack venting from the engine into the manifold and possibly clogging up the Laminova cores. Like I said, mine isn't particularly whiffy but will follow with interest, all the same.
Posted 04 May 2009 - 12:49 PM
Posted 06 May 2009 - 11:13 AM
Posted 06 May 2009 - 11:16 AM
Sounds like justification enough for not doing it, too me.Whilst doing it won't cause any harm, it will cause the laminova cores to be coated in oil and it may also require adjustment of the map to prevent detonation. That's why Courtenay don't do it.
Posted 06 May 2009 - 08:46 PM
Posted 07 May 2009 - 06:58 AM
I'll be leaving mine too, although I'm starting to think mine smells more like petrol than oil.
I'm going to check it's not something else like a leaking injector or something similar. I guess if it only smells when I accelerate then it must be after the fuel rail as this is pressurised regardless. I cannot imagine it's from the exhaust as I can smell it instantly on opening the throttle and regardless how fast I'm going (with the roof off).
I'll be moving my breather to the rear of the car as I think that's more plausible as the cause of the smell. Jon said some z22se engines really like to breathe so that could be my issue.
Posted 07 May 2009 - 07:01 AM
Posted 07 May 2009 - 07:05 AM
Posted 07 May 2009 - 08:02 AM
Posted 07 May 2009 - 08:11 AM
Hi, Paul here's what we see to be the answer to the LM850 breather path through the inlet manifold, following a thread some time back (I think it was on Z22SE?) I contacted ### my friend at Lotus just to be doubly sure that what we Hitec and & Delta have been doing for the last 5 years or so was not a bad or the wrong thing to be doing.
Although it was a few years back when he was doing the build and test work for both LM850(2.2) and the LSJ (2.0SC) His memory and gut feeling was telling him that the breather path through the head to inlet was obviously only the secondary breather path, not the primary- the primary being the main breather. So we should not have any breather issues or problems from restricting this as the primary / main breather was still in full operation.
His view was that the build manual being produced by an OEM (original equipment manufacture) was that they have to keep with full OEM emission legislation and therefore adopt a "belt and braces" approach to emissions and keep the path open, in the same way GM could not run the primary (big) breather to atmosphere.
We both agreed that from a det (pinking) point of view- that not having the oil breath back into the inlet manifold onto the lamoinova cores was an advantage, and its this reason that we do not run the primary (big) breather back into the inlet side where it will only put oil back into the inlet.
Both the LM850 (2.2) and the LSJ (2.0) are inclined to breath you can see from this clip that the LSJ with its OE secondary breather path and an additional breather still breathes under full load http://www.youtube.c...feature=related
We have had a few owners have breather fumes get back into the car, such are the aero dynamics of the VX that engine / fuel smell can seem to get sucked back. However these "smelly cars" have been cured by running the primary (big) breather with a breather filter attached, around and along the sub to the void behind the rear wheel arch liner, where the air is not dragged back to the cabin.
My man did say that he would double check the drawings for me just to be sure and get back to me if he felt we needed to change (and he generally will ) to this time I have not heard to the contrary, but as the question has been asked again I will just double check.
Cheers Jon
Posted 07 May 2009 - 09:14 AM
