Many months ago I'd spotted the vents on the Edel site, but thought they were just a bit big, so decided to make my own.
After all, in the best Top Gear tradition, "how hard could it be?"
MSV Racing supplied me with two thirds of a lower front clam, which I used as a base to form the vents. Much use of balsa foam and filler later I had a pair of masters from which I took a mould and ultimately the vents ready for fitting
The really scarey bit is cutting large holes in a perfectly good clam, God bless Dremmel,
You always wondered what was behind this bit didn't you?
Bonded in with epoxy, filled and sanded, ready to paint, grills temporarily in place
Back from the paint shop
The ironic thing is that it took me so long to make these effing things , Edel in the meantime had redesigned theirs to be practically identical to what I wanted in the first place
Next job is to run the ducting to the disks, but that's a story for another day
