Vx220 N/a Cam Availability
183 replies to this topic
#181 2-20
2-20
  • 1,317 posts
Posted 08 April 2006 - 10:44 PM
Here is a link to some new cams (5 sets) from Comp cams for the Ecotec.
The price ($440) is interesting
CAMS
Edited by 2-20, 08 April 2006 - 10:45 PM.
#182 clipping_point
clipping_point
  • 4,908 posts
Posted 11 April 2006 - 07:54 AM
Interesting find, and good prices. thumbsup Interesting that they rate the 264° cam a 3500-8000 rpm one....a bit strange? :blink: I would think a 288°-300° cam was intended for that rpm range. :unsure:
#183 2-20
2-20
  • 1,317 posts
Posted 11 April 2006 - 06:35 PM
Here are the specs for 4 of them: Street 113200 set (113201 int / 113202 exh ) grind # ECO XE252HR-11 Grind Specs 8758/8759 HR111 INT Max Gross Lift: .423 Cam Lobe Lift: .250 Advertised Duration: 252 Duration @ 0.50 Valve Lift: 210 Valve Timing @ 0.50 Valve Lift: BTDC: -5 BBDC: 38 EXH Max Gross Lift: .419 Cam Lobe Lift: .248 Advertised Duration: 256 Duration @ 0.50 Valve Lift: 212 Valve Timing @ 0.50 Valve Lift: ATDC: -6 ABDC: 38 These specs are for the cams installed at the following maximum lift centerlines: INT:110 EXH: 112 Street /Strip 113300 set 113301 INT/113302 EXH ) GRIND # ECO XE258HR-11 Grind Specs 8760/8761 HR111 INT Max Gross Lift: .440 Cam Lobe Lift: .260 Advertised Duration: 258 Duration @ 0.50 Valve Lift: 216 Valve Timing @ 0.50 Valve Lift: BTDC: -2 BBDC: 41 EXH Max Gross Lift: .436 Cam Lobe Lift: 258 Advertised Duration: 262 Duration @ 0.50 Valve Lift: 218 Valve Timing @ 0.50 Valve Lift: ATDC: -3 ABDC: 38 These specs are for the cams installed at the following maximum lift centerlines: INT:110 EXH: 112 Blower/Super Charger 113250 (113251 INT/ 113252 EXH) GRIND # ECO XE252BHR-13 Grind Specs 8758/8761 HR113 INT Max Gross Lift: .423 Cam Lobe Lift: .250 Advertised Duration: 252 Duration @ 0.50 Valve Lift: 210 Valve Timing @ 0.50 Valve Lift: BTDC: -7 BBDC: 43 EXH Max Gross Lift: .436 Cam Lobe Lift: .258 Advertised Duration: 262 Duration @ 0.50 Valve Lift: 218 Valve Timing @ 0.50 Valve Lift: ATDC: -5 ABDC: 37 These specs are for the cams installed at the following maximum lift centerlines: INT:112 EXH: 114 Turbo 113150 SET (113151 INT/113152 EXH ) Grind # ECO XE246THR-13 Grind Specs 8756/8755 HR113 INT Max Gross Lift: .423 Cam Lobe Lift: .250 Advertised Duration: 248 Duration @ 0.50 Valve Lift: 204 Valve Timing @ 0.50 Valve Lift: BTDC: -10 BBDC: 34 EXH Max Gross Lift: .419 Cam Lobe Lift: .248 Advertised Duration: 244 Duration @ 0.50 Valve Lift: 200 Valve Timing @ 0.50 Valve Lift: ATDC: -14 ABDC: 34 These specs are for the cams installed at the following maximum lift centerlines: INT: 112 EXH: 114
#184 zafiraz22se
zafiraz22se
  • 32 posts
Posted 13 August 2006 - 01:38 PM
I have been responsible for a develpoement programme for an Engineering Group (not a million miles from Hethal) I have several sets of standard camshafts from L61/Z22SE engines I gaurantee all items are low mileage with no wear or pitting These would be ideal for Re-grind or standard replacement Price £50 per engine set including postage I would even send direct to a regrinder if requested One can now have performance camshafts without their car/engine being off the road for an extended time Dr Lee J Robertson
Edited by zafiraz22se, 13 August 2006 - 01:38 PM.
