Vx220 N/a Cam Availability
183 replies to this topic
#81 clipping_point
clipping_point
  • 4,908 posts
Posted 13 January 2005 - 04:34 PM
E6GMX GM Replacement Plug-In Computer
is a replacement system for the Delco unit, no wiring harness needed....................... sounds like a dream thumbsup
http://haltech.com/e6gmx.htm
...I need to pinch myself :unsure:
#82 clipping_point
clipping_point
  • 4,908 posts
Posted 13 January 2005 - 05:59 PM
Hmmmm
#83 clipping_point
clipping_point
  • 4,908 posts
Posted 14 January 2005 - 09:16 AM
Got this form V-Max, germany: "The cam shafts are not finalised yet, and we are currently the best mapping throughout the rev range, not only maximum values. In addition it is nevertheless more difficult than we thought, to implement these cams. We can make when desired also a cam shaft profile after choice." :(
#84 griffo
griffo
  • 227 posts
Posted 14 January 2005 - 03:01 PM
Not sure how to add this to the cam table but: Had a chat with Piper Cams at the Autosport show yesterday. They have just decided to offer a reprofiled (exchange) pair of cams for the N/A VX220 for ....wait for it....£193 retail (its in their latest 2005 cam catalogue). Described as "fast road" the part no is VX22BP270. Power band is between 2000 and 6800 and claimed power increase is 10bhp. Duration is 260 degrees (inlet and exhaust) and lift is .423" or 10.74mm. I have had good experiences with Piper cams in the past and their engineer assured me there was no downside to a repro rather than a cam on blank. except a slightly smaller base circle which the hydraulic lifter can well cope with. In contrast I spent a frustrating few miunutes with a spotty and malodorous erk on the Kent cams stand who said Kent had no plans to do cams for the 2.2 VX engine and if they did "they would probably be very expensive". I plan to get some from Piper as soon as i have time to get my own cams removed and sent to them. I am pretty sure they will work well with the "ultimate competition" re-map that Chris at Regal does which not only lifts rev limits but increases fuel rail pressure. Griffol
#85 vocky
Posted 14 January 2005 - 04:17 PM
By grinding the base circle it allows the hydraulic lifter to 'pump up' slightly more thus creating more lift. Will have to find out some more about these cams, but I have used Piper cams before and have never had any problems with them. Any way the 68mm TB part number 12565553 from the 2.0 sc engine has arrived and looks like it will fit the z22se engine, just need to figure out a new intake pipe as the old one is too small :lol: PS : total cost including customs less than £100 :o
Edited by vocky, 14 January 2005 - 04:20 PM.
#86 clipping_point
clipping_point
  • 4,908 posts
Posted 14 January 2005 - 04:42 PM
These are really good news if you are looking for performance, but are on a tight budget!!! :groupjump: :groupjump: Have to get that shiny 68 mm TB as well to feed that hungry cam......
#87 vocky
Posted 14 January 2005 - 05:07 PM
Piper Cams, VX22BP270 = 260 degree, 10.724mm lift (0.423"), power band 2 - 6800 rpm, £193 + vat (probably each) which works out as £453.55 inc + postage (hope its £193 the pair :lol: I like USA prices :lol: ) Same spec as the Gozzoli 4603113 cams (probably :lol: )
Edited by vocky, 14 January 2005 - 05:16 PM.
#88 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 14 January 2005 - 05:15 PM
Ok piper sound good 2 questions How hard to remove / replace the cams (timing ect) could you do it with out a remap? Nick
#89 clipping_point
clipping_point
  • 4,908 posts
Posted 14 January 2005 - 05:18 PM
Not too hard, they measured a good gain i the states without a remap. "Instructions First from in the engine bay. Disconnect the battery, then remove the 2 nuts that hold the fuel lines to the valve cover on the drivers side of the engine, gently pull the fuel line away and over the studs, then remove the studs which hold on a ground strap and the throttle cable holder. From there unplug the IDI cover and remove the 4 bolts that hold it in and the IDI cover itself. Once that is off remove all 4 of the spark plugs and the valve cover itself. Do not pry it off once the bolts are off because you could destroy the gasket, it will most likely stick if it does use a rubber mallet or a block of wood and GENTLY tap it off Now from underneath the car. Raise the car and get the plastic cover in between the wheel and the engine off, its a couple push rivets and a few 7mm bolts I think it is. Take the serpentine belt off, use a 3/8 drive ratchet there is a spot to put it in the tensioner, have the ratchet set to off and pull the tensioner back and it will release tension from the belt, then just slide the belt off. Next step is to remove the crank pulley, I forget what size bolt it is but either use an impact to take it off, or stick a screwdriver through one of the pulley holes to keep it from spinning. If your trying to remove it without air tools its easier with the spark plugs still in the car, another way you could try is using the belt as a strap wrench around the pulley to keep the crank from spinning while your loosening the bolt, once its loose just slide a screw driver under it and it will pop/slide right off (you do not need a pulley puller to get it off, it is not pressed on). Put the crank pulley bolt NOT the pulley itself just the bolt back in the crank. Now set the engine to TDC compression, spin the crank by using the bolt that hold the pulley on. Since the spark plugs are out you can use a long screw driver or something like it to stick in the #1 spark plug hole, DO NOT USE SOMETHING THAT CAN FIT ALL THE WAY IN THE CYLINDER!!! now with he screw driver in the spark plug hole slowly turn over the engine until the screw driver is at its highest point, since its resting on the piston top the piston will push it up. When the screw driver is at its highest point look at the marks on the cam gears. The Triangle shape on the exhaust cam should be aimed somewhere close to 10 o'clock position and the diamond on the intake should be facing close to the 2 o'clock position. If the piston is up and the marks aren't near there rotate the crank 1 full turn and then the marks should be were they are supposed to. They do not need to be 100% exact, just close. The next step from here is to remove the power steering pump which locks into the intake cam, there are 2 bolts for it pull them out and just push the pump aside. Then remove the upper chain guide in between the cam gears. Now from underneath the car again. Remove the belt tensioner, its a pain in the ass, you need to use a wrench because you can't fit a ratchet, take out the 1 bolt thats on the tensioner and it will fall right off. There is a dowel pin the tensioner drops into when you have it sitting there right so you can't reinstall it wrong. The next step is to remove the engine side cover, its a bunch of 10 MM bolts, they go around the outside of the cover and there is one that isn't on the outside edge, its towards the top left (firewall side) The little small cover on the cover with 4 bolts holding it on by the top left , leave it alone. There is a chain tensioner bolt for the balance shaft chain thats on the left, its a 10 MM hex head, remove that to, once those are out, pry up on and edge of it, its not gonna come off without a fight but be careful of the gasket, once it pops off make sure you do no try to remove the gasket, the gasket goes up under the upper motor mount so it wont come off, leave the gasket on the block. Put the crank pulley bolt NOT the pulley itself just the bolt back in the crank. Once you are to this step go back up top and loosen up but don't remove the cam gear bolts on both cams. Now pull the timing chain tensioner bolt completely out. Its located on the passenger firewall side of the engine, its a big 1 1/4 inch bolt, remove it completely but be careful and do not drop it, you don't want it to come apart. Go back under and find the chain tensioner itself, upper left from the crank, its the one that runs up the side of the engine, its long and is only actually attached with one bolt. Remove that one bolt that it pivots on, and push the tensioner out of the way away from the chain. There should be quite a bit of slack in the chain now. Now go up top again and use something to hold the chain up, just so it doesn't fall all the way through to the bottom when you remove a cam gear, bungee the chain to the hood, slide a ruler or something under the chain in between the chain and area where the valve cover sits. Take a look and note where the lobes on the cams are facing for the #1 cylinder. Now start with one cam, you can remove the bearing caps, do these little by little, like 1/2 a turn on each bolt, then go back around and another half a turn on each bolt again until you can un thread them by hand. The one by the power steering pump will need to be tapped lose to same way as the valve cover. KEEP ALL CAPS IN THE SAME POSITION FACING THE SAME DIRECTION, they need to go on EXACTLY how they came off keep all the caps and bolts in EXACT order and replace in EXACT same position. The caps are numbered and have arrows on them so its not rocket science. Once you get the caps off remove the cam gear, its should only be hand tight at this time. you can let the chain hang but not let it fall in. Now remove the cam itself, you might have to tap it upwards for it to pop loose, be sure when you put the new cam in, to prelube the bearing surfaces of the caps and the head. Lay the the cam in so it is close having the lobes line up with where the stock cams lobes were, once the cam is in position torque them down in 3 steps ending with 89 in/lbs READ THAT CORRECTLY INCH POUNDS NOT FOOT POUNDS. The cap at the end of the intake cam by the power steering pump is 19 ft/lbs. Once the cam is on and tightened to spec put the cam gear back on, there is an off-centered key-way so it only fits on one way and do the other cam. When your done the chain will not be attached to anything up top at this point, just being held from falling using whatever method you rigged up earlier. Now look at the chain itself, there will be 3 colored links, from what I've heard the color is different from year to year but there are 3 colored links. You need to line up the 3 colored links with the marks on the cams and crank and since the chain is loose you can freely rotate it to the position to make the markings like up. There will be a white dot on one of the teeth on the crank, one link to that tooth, one colored link to the triangle on the exhaust cam and the 3rd colored link to the diamond on the intake cam. You will most likely have to rotate one or both of the cams to get the marks to line up. Once all three colored links are lined up with the 3 timing marks turn the crank just a little bit to get all of the slack from the chain to the tensioner side of the engine. Reinstall the 10MM that holds the bottom of the tensioner chain guide then put the top tensioner bolt back in the big 1 1/4 inch one. Make sure all the marks still line up right, then spin the engine over by hand a few times to make sure nothing is hitting. If nothing is hitting then your done. Reinstall everything you took up, I recommend putting the top back together first just in case you drop something down in the side cover it will still be off. The valve cover and IDI cover also get torqued to 89 in/lbs again INCH POUNDS. Remember to put the upper chain guide back on and the ground strap that goes to the cam cover stud. Then reinstall the bottom last in reverse order of disassembly. Once everything is back together reconnect the battery and start it up."
#90 vocky
Posted 14 January 2005 - 05:25 PM
Well according to the chaps in the USA it's a 'bit of a git' re-timing the chain/ cams. BUT they do not have Haynes manuals (or similar) and according to the Haynes it is quite straight forward, if you are mechanically minded that is. Personally I do not see a problem, but I have rebuilt many engines over the years. A re-map would increase power even more with the cams, but it is probably better to fit the cams then get a re-map, as I will do. With cams it is better to free up the air intake and gas outlet (exhaust) before actually upgrading the cams. Then a re-map should bring it all together.
Edited by vocky, 14 January 2005 - 05:30 PM.
#91 Badz24
Badz24
  • 15 posts
Posted 14 January 2005 - 05:30 PM
ya if you know what to keep in mind doing the timing on this motor isnt that bad. Ive built a few motors in my (short) time. Yet i still got it a tooth off when i put my motor together the first time. It was very frustrating.
#92 NickB787
NickB787
  • 7,813 posts
Posted 14 January 2005 - 07:00 PM
bulk buy guys?
#93 clipping_point
clipping_point
  • 4,908 posts
Posted 14 January 2005 - 07:23 PM
Yes please. thumbsup Depends if it is £193 for 2 (cheap) or 1 (expensive/better alternatives) :unsure:
#94 griffo
griffo
  • 227 posts
Posted 14 January 2005 - 07:28 PM
I have probably missed something somewhere but who supplies those really interesting looking throttle bodies???? Griffo
#95 clipping_point
clipping_point
  • 4,908 posts
Posted 14 January 2005 - 08:08 PM
It is a standard GM thingy, they hand it out for free, and it IS a miracle!
#96 vocky
Posted 14 January 2005 - 08:52 PM
Group buy at £193 (or less) a pair - yes please, £193 each maybe :lol:
The 68mm TB is available from saturnpartspeople.com , they do ship worldwide.
Enter part number 12565553 and Saturn as the model
Cost including delivery + customs is @ £100 :o
I have just got one from them, as soon as it's fitted I will post on this thread.
The 68mm TB is mentioned on another thread somewhere but I cannot remember which one :lol:
Edited by vocky, 14 January 2005 - 09:03 PM.
#97 clipping_point
clipping_point
  • 4,908 posts
Posted 15 January 2005 - 07:43 AM
Update! Looking better ´n better! thumbsup
Edited by clipping_point, 15 January 2005 - 07:52 AM.
#98 NickB787
NickB787
  • 7,813 posts
Posted 15 January 2005 - 09:36 AM
How about this idea If we use piper cams does anyone have some na cams to hand, if they do we can send them first to be modded that way our cars aren’t off the road for long. Once the cams have been returned and fitted that person can send his cams off to another member and then repeat the process again takes a bit longer but the car is usable for longer mainly for people like me who use it as there main car. ?????????????????
#99 clipping_point
clipping_point
  • 4,908 posts
Posted 15 January 2005 - 10:06 AM
A convenient way, but not applicable for a group buy, when they machine all at once, I guess. The standard TB here. One can see it is the same electrics, only shifted 180° on the 2.0 SC one
Edited by clipping_point, 15 January 2005 - 10:07 AM.
#100 clipping_point
clipping_point
  • 4,908 posts
Posted 15 January 2005 - 10:07 AM
Piccy of standard 58 mm
