Vx220 N/a Cam Availability
183 replies to this topic
#121 skogshuggarn
skogshuggarn
  • 1,088 posts
  • Interests:weightlifting and spending money on my car
Posted 22 January 2005 - 02:25 PM
Minimum of 75mm pipework to fit onto the 68mm TB neck :tumble:
Then my ITG is waist of money :beat:
#122 PaulCP
PaulCP
  • 6,066 posts
Posted 22 January 2005 - 03:29 PM
Areawise the move from 58 to 68 mm is equivalent to the move from 147 HP to 202 HP airflow-wise.
So the 68 mm TB would fit PaulCP:s or ShinyAndys cars really well IMHO. Could free up several HP almost FOC.....................
Hmmmmmmmmm ;)
Tempting - could mate with the Dbilas quite well :rolleyes:
AMD stage 4 Thorney?????????
Edited by PaulCP, 22 January 2005 - 03:31 PM.
#123 clipping_point
clipping_point
  • 4,908 posts
Posted 23 January 2005 - 11:37 AM
The loom needs extending @ 150mm as the plug has moved 180 degrees, so swapping them with the extensions (whilst soldering them) is a better way.
How should one make the extension? To have something that plugs right in and extends 150 mm sounds great, but where do we find the necessary female/male (shemale? :blink: ) connectors? :tumble:
#124 vocky
Posted 23 January 2005 - 12:16 PM
Personally I would cut one pair of wires at a time, then solder a new section of wire onto one end of each wire, fit 2 pieces of heat shrink sleeving to each wire, then solder the other ends (swapping colours where required, like E+F) and finally slide the heat shrink sleeving over the soldered joins before heating the sleeving to form a good seal. (or you could just use insulation tape on the soldered join) Then repeat for the remaining wires, this saves getting the wires connected wrong :D . But if the plugs were available :unsure: , an adaptor extension could easily be made :D , and this could swap the wires without any other alterations thumbsup . But the dBlias inlet manifold must require an extension anyway, as the TB is at the side of the engine, so can someone with a dBlias let us know how the cable loom was extended please :tumble:
Edited by vocky, 23 January 2005 - 12:20 PM.
#125 minime
minime
  • 1,876 posts
  • Interests:skiing, socialising......
Posted 23 January 2005 - 12:22 PM
if i remember rightly the dbilas kit has extentions for the throttle body!
#126 clipping_point
clipping_point
  • 4,908 posts
Posted 23 January 2005 - 12:23 PM
Yes, and it could be returned to original, if necessary. All these extensive mods contain a portion of uncertainty :unsure:
#127 minime
minime
  • 1,876 posts
Posted 23 January 2005 - 12:38 PM
does anyone know if the larger throttle body will fit directly onto the existing mountings?
#128 vocky
Posted 23 January 2005 - 01:09 PM
If the fixing holes were enlarged it would bolt on, but the standard inlet manifold air intake hole is only 60mm and the gasket would not seal properly. So a 5mm plate mounted onto the standard inlet and the 68mm TB bolted on top of that would be better, also it would then clear the EGR pipe. I bought my 68mm TB to fit onto either a Venom or dBlias inlet manifold, as the standard inlet will not benefit as much with the increased flow possible with the enlarged TB, so I never expected it to fit a standard inlet - but I was surprised that it could almost bolt straight on.
Edited by vocky, 23 January 2005 - 01:09 PM.
#129 vocky
Posted 23 January 2005 - 05:26 PM
The 68mm TB would fit the saab manifold,
#130 clipping_point
clipping_point
  • 4,908 posts
Posted 23 January 2005 - 08:38 PM
Interesting!! thumbsup Does it have equal length runners and a plenum? Turbo inlet design is not as crucial, u can just pump up the pressure a step...
#131 vocky
Posted 23 January 2005 - 08:51 PM
That is the downside of the Saab inlet, it does not flow so well, but maybe with the 68mm TB it might improve things :unsure:
#132 griffo
griffo
  • 227 posts
Posted 13 February 2005 - 05:56 PM
I see Courtenay are now offering cheapish repro cams for the n/a. Does anyone know anything about them? Griffo (a fish)
#133 minime
minime
  • 1,876 posts
Posted 13 April 2005 - 05:56 PM
just got the info on my dbilas cams..... looks as if i different inlet/outlet... code refs..680/690 duration 256/248....pk time 115/105....vavle lift 12mm not sure on the other figures as i cant read what has been written :unsure:
#134 vocky
Posted 12 July 2005 - 07:27 PM
Just fitted the 68mm TB (with a VW golf inlet manifold) and the engine runs :groupjump: I need to finish off the install as various pipes blanked off or not connected :lol: Once it's finished I will post the results of a road test (hopefully not 6 months again :lol: ) PS I blanked off the EGR valve (fitted a piece of metal between the gasket and valve) a few weeks ago. No performance gain but stopped the engine from revving high on first start up.
Edited by vocky, 12 July 2005 - 07:35 PM.
#135 clipping_point
clipping_point
  • 4,908 posts
Posted 12 July 2005 - 11:34 PM
PS
Great news! thumbsup
Interesting blanking off the EGR thingy, was it hard?
#136 vocky
Posted 13 July 2005 - 06:51 AM
No very easy :D , just used the gasket and traced around it onto a sheet of stainless steel to produce a blanking plate, drilled the 2 holes and created a small dent in the middle (the valve protudes a little).
Then simply fitted the gasket, then the blanking plate and finally the EGR valve.
The reason I tried this first was to see if it caused any eml, plus my new inlet manifold did not have a fitting for a EGR pipe :lol:
So after a few days I completely removed the EGR pipe (inlet - head) and fitted a suitable blanking disc in the standard inlet manifold (strangely the engine stopped high revving at cold start up without the pipe :blink: )
So without the EGR pipe a 68mm TB would almost bolt straight on to the standard inlet, all that would be required is an adaptor plate and the plug wiring, plus a little porting of the inlet section below the TB :lol:
#137 cicastol
cicastol
  • 423 posts
Posted 13 July 2005 - 07:40 AM
I could post some photos,very easy you just need a thin metal sheet (0,2 0,3mm range) to make a blank gasket,need some grind the EGR valve to make it plane but very easy job.... thumbsup
#138 clipping_point
clipping_point
  • 4,908 posts
Posted 13 July 2005 - 09:19 AM
Please do! thumbsup
#139 cicastol
cicastol
  • 423 posts
Posted 13 July 2005 - 11:23 AM
#140 cicastol
cicastol
  • 423 posts
Posted 13 July 2005 - 11:24 AM
2Nd
