Vx220 N/a Cam Availability
#141
Posted 13 July 2005 - 11:37 AM
#142
Posted 23 August 2005 - 09:50 AM
Thorney, on Jul 13 2005, 12:01 , said:
Do you have a RR dyno?Just catching up on this thread - great stuff.
You may be interested to know that we use the Piper cams in conjuction with the TB based stage 4 and on the stage 3 NA tunes we've done.
#143
Posted 29 October 2005 - 04:03 PM
vocky, on Jan 19 2005, 20:58 , said:
vocky, do you know how the TB feeds back throttle position to the ECU. I assume its one of the potentiometers, but which oneUpdate for wiring of 68mm TB.
Basically there are 8 pins, pin 1 + 2 are for the motor, then there are 2 potentiometers - pins 3 + 6 with 8 as the wiper
and pins 4 + 7 with 5 as the wiper.
8 7 6 5
1 2 3 4
pin configuration used, viewed with plug clip at top
As the 68mm TB opens the opposite way to the standard TB, the wires to pins 3 + 6 and pins 4 + 7 need swapping around.
So that wire 3 goes to pin 6 and wire 6 goes to pin 3, then wire 4 goes to pin 7 and wire 7 goes to pin 4.
This changes the potentiometer output to the same as the original.
I will update with cable colours once the TB is fitted.
#144
Posted 16 December 2005 - 04:51 PM
speedster, on Oct 29 2005, 16:27 , said:
sorry for the extremely long wait for a replyVocky, do you know how the TB feeds back throttle position to the ECU. I assume its one of the potentiometers, but which one
It appears both potentiometers feed a signal back to the ecu, one signal raises the resistance the other lowers it
#145
Posted 19 December 2005 - 01:11 PM
Now I need a recommendation for a set of cams that will work with a race ported head. JBP are offering me the following kit but should i stick with stage one cams if I have a Dbilas intake and Full Milltek exhaust (plus maybe the 68mm TB) attached?
- Stainless Steel 1mm+ Intake, Stock sized Exhaust valves
- GM ECOTEC Adjustable Timing Gears
- JBP ECOTEC Stage 1 Camshafts
- JBP/WISECO Forged Aluminum Pistons, Locks, Pins and Rings
- Fully Race Ported Head
- 5 Angle Valve Job
- Bronze Valve Guides
- HD Valve Springs
- HD Retainers
- Chromemolly Steel Locks
Thorney, could you offer a similiar kit? Is so what's your price
#146
Posted 19 December 2005 - 01:42 PM
#147
Posted 19 December 2005 - 03:04 PM
clipping_point, on Dec 19 2005, 14:06 , said:
OKWhat does this silly Stage 1 business mean? It is lift and duration that is interesting!!
Myself i will have:
- Race ported head with 11,5:1 CR + 3-angle-job
- Double valve springs
- Ti retainers
- Adj cam gears
- Piper 267° regrind
According to all sources the +1 mm valves are a useless investment.
#148
Posted 19 December 2005 - 03:15 PM
#149
Posted 19 December 2005 - 03:23 PM
Edited by clipping_point, 19 December 2005 - 03:58 PM.
#150
Posted 19 December 2005 - 04:14 PM
#151
Posted 19 December 2005 - 04:17 PM
#152
Posted 19 December 2005 - 04:35 PM
vocky, on Dec 19 2005, 16:41 , said:
Dude and I bought adjustable cam gears from carcustom at $235.personally I would say don't bother with adjustable cam sprocketsÂÂ
modern cam grinding machines are very accurateÂÂ
As I see it (from what I´ve heard):
- Some gains can be accomplished from using a different "lobe separation" other than standard
- to match the harmonic pulses in the inlet and outlet the cam timing is crucial
You are building a new machine, so all ways to make adjustments are good. But you got to know your business to set it up propely (and I don´t)
Edited by clipping_point, 19 December 2005 - 04:37 PM.
#153
Posted 19 December 2005 - 07:11 PM
clipping_point, on Dec 19 2005, 16:59 , said:
that's the main reason many don't get any gains (infact they loose powerBut you got to know your business to set it up propely (and I don´t)
set up correctly and a couple of hp is possible
it's just the '£' vrs 'hp' 'is it worth it' syndrome
#154
Posted 19 December 2005 - 07:28 PM
No problem. However, there is a ratio between the exhaust and intake valve
that has to be matched. A 1mm+ size is the largest we can go, otherwise a
full run of custom valves would have to be manufacturered: and would be very
expensive.
Edited by speedster, 19 December 2005 - 07:28 PM.
#155
Posted 19 December 2005 - 08:00 PM
clipping_point, on Dec 19 2005, 16:38 , said:
AgreedSome guys have had problems with the Piper cams and high revs.
I´m thinking that by using double springs, and Ti retainers, the cam followers will work to +8000 rpm with no problem.
Hi revs and Piper cams don't work too well, you need more than just cams to get a decent gain with longevity.
#156
Posted 19 December 2005 - 08:19 PM
speedster, on Dec 19 2005, 19:52 , said:
The size of the standard valves is not the issue. Instead the ports are too small.I asked JBP for bigger valves and this is what they replied with:
expensive.
My ported head retain the standard valves, the same goes for Dudes 230-240 HP monster.
#157
Posted 19 December 2005 - 08:40 PM
#158
Posted 19 December 2005 - 08:55 PM
speedster, on Dec 19 2005, 21:04 , said:
Can it be any cheaper? Cost?
JBP can grind the cams to the Piper specs too.
But of course, a new grind would be nicer than a regrind i guess?
#159
Posted 19 December 2005 - 09:16 PM
clipping_point, on Dec 19 2005, 21:19 , said:
Purchasing the cams as part of the JBP Race head kit, no extra charge for specifying the cam specs. Grind is from blanks.speedster, on Dec 19 2005, 21:04 , said:
#160
Posted 19 December 2005 - 10:00 PM
