Leaking Vx
5 replies to this topic
#1 Guest_niceandneat2000 (Guest)
Posted 30 December 2002 - 11:37 PM
Has anybody noticed if their VX is leaking water around the joins of the footwell. Since running the car in more wet weather it appears the footwell on both passenger and driver's sides are not properly sealed on my car. Anybody else noticed this? The give away is soaking wet carpets. My other crumble is the fogging up of both front and rear lights, have we had a satisfactory answer from Vauxhall yet? I look forward to your thoughts Regards Chris
#2 Guest_minus8 (Guest)
Posted 31 December 2002 - 09:58 AM
Try keeping an eye on the Elise BBS, they have a good archive which you can search. This link should give you some suggestions.
http://www.british-c...110241841062377
Mark
#3 CDR
CDR
  • 76 posts
Posted 31 December 2002 - 12:12 PM
I have had two VX's - the first was rejected and replaced - and they have both leaked into the front passenger footwell. The first one was worse, on a particularly wet day I could watch the trickle running down the chassis whilst I was driving. When I was at the Lotus factory in November I mentioned this and was told it is a common fault!!! :D Regards Colin
#4 VEX
VEX
  • 2,230 posts
Posted 02 January 2003 - 02:26 PM
:) Checked my carpets today. Drove to work in a near constant flood! Not wet, just a little damp from my shoes and thats it. The VX still astounds me for its drive and poise in the wet. One happy owner.(except my light switches are on the way out!) Cw
#5 kirkvx220se
kirkvx220se
  • 159 posts
Posted 02 January 2003 - 07:07 PM
I,ve never noticed any water in the footwells,but had my windscreen seals replaced 6 weeks after delivery of the car.Had my head lights replaced first week but still mist up,and have asked but not been given a reply yet!Ive also had my pass door lock changed and now Kneed my drivers done,But we should be thankfull,IM a member of Scottish elise and they have a lot more probs with there cars than i could believe. :ph34r:
#6 Flecski
Flecski
  • 274 posts
  • Interests:Hockey - playing. Other sports - drinking while watching. Bit of photography.
Posted 03 January 2003 - 05:47 PM
When I got to work yesterday I noticed my passenger mat was soaking and the drivers was quite wet. Took all night to dry out the drivers. I do remember having to drive through quite a bit of water on a roundabout - might have had something to do with it. I'll check again after driving tomorrow, as I still need to finish drying the passenger mat. . .
