just spoke with mantaparts (ohio, USA), specialized on GM engines.
http://www.mantapart.com/
explained my situation, and they said they deal with this kind of charger/turbo mods all the time, so can handle any piston/conrods request....
I briefly explained'em them the Delta-motor kit, and that I will need a lower compression rate.... no prob they said, just send us a stock piston and a conrod, and they will make a forged set (pistons+conrods) with the required compression rate for about 1000 usd.
I can also choose to increase the bore, but I guess its better not to....
helluva cheaper than in italy, where spec-made pistons go for 700/1000 euros, and conrods 1200......if carrillo's are asked, its 380 euros EACH....
they claim making conrods using the same Carrillo specs and bolts, so they should be by far exceeding a lightweight speedy's requirements....
also they can (and actually endorse it) have the lubricating hole drilled in the conrods as well, just send a pic on how big you need it....
..at this point, it could become MUCH cheaper to skip the kompressor kit and "only" go for forged pistons, conrods and cams, (like the majority of friends and tuners suggest me...
) along with a brand new, fully-programmable EFI module..... I guess 180-190 hp are quite accessible....
decisions, decisions....
