How To Check Boost Control Solenoid
Posted 01 July 2009 - 06:13 AM
Posted 01 July 2009 - 07:16 AM
Posted 01 July 2009 - 07:19 AM
Edited by Ouija Board, 01 July 2009 - 07:19 AM.
Posted 01 July 2009 - 07:29 AM
Posted 23 July 2009 - 01:38 PM
Posted 23 July 2009 - 03:18 PM
Posted 23 July 2009 - 03:35 PM
just thinking that the BCS is not actually changed when doing a turbo swap out as its located by the inlet manifold? only the wastegate actuator and solenoid comes as part of the turbo
Yes that must be correct as my car has had these symptoms since I bought it in Jan and its had a new AET tubo since then and the fluttering was still present.
All gone now though!
Posted 23 July 2009 - 03:45 PM
Posted 23 July 2009 - 03:49 PM
where abouts is the solenoid located? sorry for been a complete mechanical numpty!!
At the right hand side of the heat shield where the intake pipe goes into the turbo, that the intake pipe off and you will see a little solenoid with 3 pipes and a connector joining into it. Thats the one...
Posted 23 July 2009 - 03:53 PM
thanks!
Posted 23 July 2009 - 04:31 PM
Posted 26 May 2010 - 09:59 AM
Posted 26 May 2010 - 11:54 AM
Are all the relevant boost pipes accessible from the bottom or do you need to take one or both of the rear wheels off to check some of the pipes?Check all the boost pipes. I find it easier to remove the middle undertray.
Steve.
Posted 26 May 2010 - 12:49 PM
Steve.
Shouldn't need to take any of the wheels off. You really do need to get under the car to inspect some of the lower boost pipes though.
Check all the pipework from the recirc valve back to the inlet BCS. Occasionally the pipes can pop off the solenoid. I have bypassed mine altogether.
Posted 26 May 2010 - 03:54 PM
Posted 26 May 2010 - 09:58 PM
Will do. Thanks for the help chaps! Now I have to find a time when I can get underneath!
By inlet BCS do you mean the turbo inlet or the inlet manifold BCS… or both
Inlet BCS is the one by the inlet manifold, closest to you as you look from the back - this one connects directly to the recirc valve.
Posted 26 May 2010 - 10:09 PM
Cheers. I checked the pipes that attach to this BCS and they all seem to be attached alright. I am planning on removing them soon and performing the 'test' mentioned by the OP
To be honest i'm hoping to find something as simple (and cheap) as a split boost pipe but I wouldn't cry if paying £20 for a new BCS sorted the damn noise.
Posted 29 May 2010 - 10:42 AM
Looks like I need a new boost control solenoid (due to chatter on lift off etc)
- sent an enquiry to Autovaux and they came back with this:
VALVE,SOLENOID,TURBOCHARGER WASTEGATE ACTUATOR VACUUM CONTROL, price is £20.45 + vatP&P from £2.63
Does this sound like the exact part i need? Sounds right to me but can anyone confirm or got a part number?
Ideally I'd like to order it by the time they shut (1pm) this avo
Many thanks!
Posted 07 April 2013 - 08:31 PM
