Heat Shield Replacement
Posted 23 July 2009 - 08:59 AM
Posted 23 July 2009 - 09:02 AM
Posted 23 July 2009 - 09:08 AM
Posted 23 July 2009 - 10:14 AM
Posted 23 July 2009 - 02:48 PM
Posted 23 July 2009 - 03:00 PM
Posted 23 July 2009 - 06:49 PM
...... it looks like it might be accessible if I drop the back box off?
I'm hoping it's not a clam removal job!
Anyone tried it?
Yes.
Although it wasn't 'I' who tried it but the other half
We were replacing the zaust system anyway so access to the mesh and heat shield (nick-named the mono-brow...) was indeed possible.
Be warned, as Techieboy pointed out it is practically welded on with that black resin/glue stuff
Posted 23 July 2009 - 06:51 PM
It would potetially be easier to cut the heatsheild off the new bit of mesh and bond it on to the old mesh with some 'chemical metal' or similar
Posted 28 July 2009 - 03:25 PM
never had a prob, and my exhaust gets very hotDoes it need one? - Depends whether your rear number plate is susceptible to heat damage or not
Posted 16 September 2009 - 06:06 PM
Posted 18 September 2009 - 04:55 AM
Hi Guys,
My heatshield came away from the wire mesh this afternoon. I still have the wire mesh. Should I weld it back on or
is it really needed.
I have a trip to the Nurgburgring arranged for tomorrow. Typical isn't it.
I take it you still have the heat shield? I just used Tigerseal to stick it back on with and so far so good. Whether it's needed or not it only took 5 mintues to fix so it was worth it for aesthetic reasons.
Posted 18 September 2009 - 07:32 AM
Posted 18 September 2009 - 11:38 AM
Posted 18 September 2009 - 12:31 PM
TMS broke mine off when they removed my Clam. John said it was not needed and they all fall off when Clams are removed anyway.
That sort of thing is one reason why i'd rather use courteneys. They knock a bit of your car off and rather than fix it their attitude is 'oh you dont need it anyway'!!!! WTF
Seen quites a few melted numberplates, and even if it doesn't help against that, i think it looks sh** without it
