Revised Rear Clam Removal Guide
#21
Posted 13 July 2013 - 07:32 PM
#22
Posted 15 July 2013 - 01:02 PM
Does the engine start with the rear clam off?
I have my engine light on and she no start.
Yes I drove it with the rear clam off
as artic says, just make sure the relays and fuse are seated correctly
#23
Posted 15 July 2013 - 01:09 PM
on the turbo, just make sure the ecu earth wire is connected and it should start
#24
Posted 15 July 2013 - 02:34 PM
Could someone elaborate on where the relays are that I need to check? The rear light relays are obviously not connected.
When I turn on the ignition I normally hear the charge cooler water pump running but now I get nothing except the engine light illuminated and it doesn't even try to turn over.
I changed the gear cables, so I've been knocking about in the cabin too.
I also gave the engine bay a bit of a wipe down, so potentially I've knocked something
#25
Posted 15 July 2013 - 02:44 PM
They're normally in the boot - mentioned in this post here: http://www.vx220.org...guide/?p=920970
#26
Posted 24 July 2013 - 06:40 AM
#27
Posted 01 April 2018 - 05:15 PM
Does somebody keep a copy of the PDF version of the guide? The link does not work anymore... I would appreciate if you could re-post or PM. Many Thanks!
#28
Posted 03 April 2018 - 09:03 PM
I think I have one somewhere, but otherwise have a look at the one with the pictures I made :
http://www.vx220.org...al-photo-guide/
Pretty much covers all.
