Creaking Noise From Front Brakes?
12 replies to this topic
#1 TOMVX220
TOMVX220
  • 392 posts
Posted 19 August 2009 - 08:14 PM
Hi This just started tonight. I gave the VX a wash and polish and set off for a drive in the sun. About 10 minutes into the journey I braked and noticed that there was a loud and strange creaking type noise coming from the front. It seems to be coming from the front driver's side caliper!! If the car is stationary and the brake pedal is pressed the noise appears, if you're rolling down a hill and press the pedal it makes the noise too!! Im a little concerned and could do with some advice on first things to investigate!!! Hoses, caliper, pad???? ETC! Thanks
#2 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 19 August 2009 - 08:17 PM
Probably just brake dust build up - a good clean may well sort them out :unsure:
#3 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 19 August 2009 - 08:19 PM
If it's there when the car is stationary check the caliper mount bolts are secure , any vibration when driving /braking ?
#4 TOMVX220
TOMVX220
  • 392 posts
Posted 19 August 2009 - 08:20 PM
Hmmm, thanks for the suggestion but it seems to be way more than just brake dust build up! I tried cleaning around as much as possible. Ive never heard anything like it on any car before!
Its a kind of creaking / grating noise, not a squeak.
#5 TOMVX220
TOMVX220
  • 392 posts
Posted 19 August 2009 - 08:23 PM
Yeah, maybe that is a good place to start. Performance doesnt seem to have been affected, they appear to function fine, although I dont have much trust in them when their making that noise!!
The other strange thing is that the noise isnt their if the car rolls backwards, just when rolling forwards!!??
#6 TOMVX220
TOMVX220
  • 392 posts
Posted 19 August 2009 - 10:19 PM
Any other ideas.............?
#7 SteveA
SteveA
  • 9,156 posts
Posted 19 August 2009 - 11:40 PM
:yeahthat:
Is a known problem if you have 1144 or other carbon rich pads.
Take the pads out & take the caliper off, give it a good clean and put it back together.
#8 mikeerhymes
mikeerhymes
  • 40 posts
Posted 26 July 2010 - 10:53 PM
:yeahthat:
Hi Tom
Did this sort out your problem? mine has been like this for a while now, as there has been no loss in performance it hasnt really bothered me. I DO have 1144s fitted, when you say give it a good clean is there any need to replace seals etc?
thanks
#9 ineedtheturbo
ineedtheturbo
  • 1,150 posts
  • Interests:Vx220
Posted 27 July 2010 - 01:52 PM
Mine creak like mad, mainly when hot. Not sure why it does it though! Did the clean take care of it?
#10 SimonM
SimonM
  • 247 posts
Posted 27 July 2010 - 01:55 PM
Possibly daft question but are you sure it's the calipers? I had a lot of creaking down there that I assumed was the brakes and it turned out to be the actual brake pedal
#11 ineedtheturbo
ineedtheturbo
  • 1,150 posts
  • Interests:Vx220
Posted 27 July 2010 - 02:50 PM
Mine sounds like the pedal... How did you sort? WD40?
#12 ken355
ken355
  • 87 posts
Posted 28 July 2010 - 11:58 AM
Mine did this before too. I just changed the pads and it took care of it. It is usually a build up of dirt on the back of the pads.. Though you should also check the capplier isnt seized at one end as it would cause it to squeek too.
#13 euphoria
euphoria
  • 276 posts
Posted 28 July 2010 - 12:38 PM
i had the same sorta thing on my previous Civic Type R, i had ferodo 2500 pads on them, and when ever i pressed and released the pedel i could here a creaking noise, i changed my pads with new ferodo 2500 all round and the noise stopped! I later found out it was because my pads were low... :rolleyes:
