Central Locking On An Na!
68 replies to this topic
#1 d4nnyk
d4nnyk
  • 769 posts
Posted 21 August 2009 - 07:10 AM
Hi, I'm going to start installing central locking in my NA tomorrow, first of all I am just going to wire it up so it operates via the key (both sides) but ideally I want it to work via the existing remote. Now I know the turbo alarms have the central locking output cables on it, but does the NA?? are they the same modules?? Would like to know if someone has wired central locking to their NA alarm system, as I don't really want to pull the dash apart for no reason. Oh, mines a 2003
#2 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 21 August 2009 - 10:22 AM
Alarm should have the same outputs to trigger central locking. You will need the central locking control module or some relays though.
See here for circuit diagram.
Edited by Ouchie, 21 August 2009 - 10:25 AM.
#3 d4nnyk
d4nnyk
  • 769 posts
Posted 21 August 2009 - 10:30 AM
Thanks for the circuit diagram, that will help alot. Yeah I have a central locking control module with the two wires for connecting to an alarm.
#4 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 21 August 2009 - 12:07 PM
Take lots of pics and post them up so I can copy :D
#5 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 21 August 2009 - 12:12 PM
:yeahthat: sounds like a worthwhile mod thumbsup
#6 d4nnyk
d4nnyk
  • 769 posts
Posted 21 August 2009 - 12:22 PM
Yeah I will take pictures, I will let you know how I get on, as long as I can drill the holes in the doors and pillars to feed the wires through I think it should be fairly easy.
#7 Geebo
Geebo
  • 533 posts
Posted 21 August 2009 - 01:04 PM
The doors had to come off mine to be drilled when I had it fitted to my NA at my local stealer.
#8 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 21 August 2009 - 01:13 PM
*suddenly not so interested*
#9 d4nnyk
d4nnyk
  • 769 posts
Posted 21 August 2009 - 01:15 PM
Don't say that!!! I don't want to take the doors off. Where there's a will there's are way!!! Plus I don't trust dealers, they will say the doors have to come off just to charge extra time (and I know this because I work for a dealer, who will remain nameless).
Looks like enough room to get a dremel with a drill bit in it between the doors (fingers crossed) Wish me luck, might be a few swear words tomorrow!!!!
#10 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 21 August 2009 - 01:46 PM
doors are a doddle to take off though tbh.
#11 Cookies220
Cookies220
  • 2,721 posts
Posted 22 August 2009 - 07:09 AM
Good luck fella! A worthwhile mod. I wouldn't do without central locking.
#12 182ian
182ian
  • 426 posts
Posted 22 August 2009 - 08:48 PM
Had they not heard of an 90 degree angle drill? Surely you can drill the front of the door without removing it??
#13 Mac vx
Mac vx
  • 174 posts
Posted 22 August 2009 - 09:03 PM
I had central locking fitted to my old na, i have a toad cat one fitted and used vxt central locking motors there the only ones that will fit in the small space in the door. all done for under £300 remember 2 motors cost £90 for vauxhalls.
#14 savvy
savvy
  • 2,524 posts
Posted 23 August 2009 - 09:46 AM
*watches thread for a how to* thumbsup
#15 siztenboots
Posted 23 August 2009 - 10:00 AM
are you fitting the extra emergency battery and the secret button same as OEM Turbo build would rather leave it unlocked than have someone slash the roof
Edited by siztenboots, 23 August 2009 - 10:01 AM.
#16 techieboy
Posted 23 August 2009 - 10:05 AM
BFOD. I nearly always leave mine unlocked.
#17 vocky
Posted 23 August 2009 - 10:08 AM
it won't need the vxT secret switch as the door key locks will still be in place thumbsup
#18 d4nnyk
d4nnyk
  • 769 posts
Posted 24 August 2009 - 08:12 AM
I am afraid the "secret switch" is still need, once central locking is in place the normal locks don't work. I am going to installing a secret switch but not in the "not" so secret turbo location
#19 techieboy
Posted 24 August 2009 - 08:26 AM
Wouldn't it be more sensible to permanently attach some charging leads to the main battery and leave them behind the nearside front arch liner, so that in the event of a dead battery and no access to the bonnet release, you could inject some power from outside. Would also be handy in the event of the bonnet release going pop.
#20 d4nnyk
d4nnyk
  • 769 posts
Posted 24 August 2009 - 08:36 AM
Well, I started the central locking on Saturday, I haven't finished yet but this is how it went:
1) the kit - off EBay
This kit has two masters, so both doors can be unlocked by either side, so in theory if one off them fails the other door will still open.
2) Off Side Door Lock
There are two places you can attach the rod, one you can see here the other is out of view, but used in the passenger door don't know which one is best.
3) Offside Door - mount motor
4) Offside Door, run cables to pillar
Managed to drill the holes without taking the door off and without a 90 degree drill adaptor
5) Then done the same to the Nearside
I have not finished wiring it up, planning to finish it all on Wednesday
Oh, the windows clear the central locking motors fine, so you do not have to fit turbo ones
Edited by d4nnyk, 24 August 2009 - 08:43 AM.
