Central Locking On An Na!
68 replies to this topic
#61 M3KDJ
M3KDJ
  • 156 posts
Posted 15 September 2009 - 05:50 PM
The only surefire way of ensuring you can get in is to fit a mechanical device attached to the same point as the locking motor in the door that pulls the lock to the open position when pulled from outside....
Is that "mechanical device" to open the lock not called a key?? :closedeyes:
(Not sure on the inner workings of the VX lock, so maybe the key is useless when the CL is activated?)
Keys are rendered useless when the central locking is fitted - the VX locking mechanisms are very bizzare!
#62 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 15 September 2009 - 09:27 PM
:yeahthat: I removed the black plastic panel in the door to see the lock mechanism. Underwhelmed is an understatement :rolleyes:
Edited by Ouchie, 15 September 2009 - 09:28 PM.
#63 Benjamin
Benjamin
  • 61 posts
Posted 15 January 2011 - 02:31 PM
All done!!!! Central locking now fitted to my NA and connected to the orginal alarm, so operated via the alarm fob!!! I think in totally it has taken me about 14 hours and £30. Will put up some more photos tomorrow.
£30 ?!!! I got quoted £300 to get this fitted professionally ... I may have to consider this ... I may need to enlist an electrical engineer friend though ... when it comes to things that are electric as far as i am concerned you push a button and, subject to a power supply i.e. wall socket or battery ... it works :wacko:
I think this is a definite worthwhile mod ... i few weeks ago, when all the snow was around, my lock froze shut ... i had no other way to get in the car but to p*ss on the lock ... i was literally wounded when i eventually got in the car :unsure:
Which central locking kit was it ???
Edited by Benjamin, 15 January 2011 - 02:32 PM.
#64 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 15 January 2011 - 03:45 PM
When the whole lock barrel freezes, it doesn't make much difference if it is locked or unlocked, as you can't push it to open the door. ;)
Make yourself a lock cover (see below) put some lock de-icer / anti-freeze inside the cover before putting on the lock, and it won't freeze. thumbsup
#65 Benjamin
Benjamin
  • 61 posts
Posted 15 January 2011 - 04:32 PM
What is the lock cover made of ?? :huh:
#66 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 15 January 2011 - 04:50 PM
There's a thread on here about it somewhere...
It's made out of a piece of hose pipe, split down the side (as standard hose pipe is not wide enough to go around the lock) then patched up so there are no gaps, then another peice of hose pipe cut into a circle shape to form the lid. Glued together.
Mine fits quite snug around the lock.
I then painted it with waterproof silver paint, which seals any small gaps, makes it waterproof, and also stops it from standing out when you leave it on your car lock when parked up.
#67 J4EY D
J4EY D
  • 3,236 posts
Posted 17 January 2011 - 09:30 PM
Good work thumbsup
I might have to make a couple of these... thats if i dont glue my fingers together again :beat: :lol:
#68 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 17 January 2011 - 09:35 PM
I only have the one, on the driver's door. As long as that opens, that's enough. thumbsup
#69 J4EY D
J4EY D
  • 3,236 posts
Posted 17 January 2011 - 10:11 PM
Yeah thats a good shout thumbsup
