But plastic, can it handle the bending load? What is the material of the OEM subframe schim and how thick are they?
BR, Per
Posted 03 October 2015 - 04:57 PM
BR, Per
Posted 03 October 2015 - 09:18 PM
I would be very surprised if it's bends due to it being flush to the subframe and the plastic being soild. The only weight it's taking is the rear clam and there only there to space the clam so the bodywork panels line up.But plastic, can it handle the bending load? What is the material of the OEM subframe schim and how thick are they? BR, Per
Posted 04 October 2015 - 08:55 AM
Who is this Dan? He seems to have lost/broken/poorly fitted a lot of things!?
He lost, broke and poorly fitted plenty on mine also. I can't say too much at the moment as i have a case against him in the small claims courts shortly.
Posted 04 October 2015 - 09:01 AM
But what is the material of the OEM schim? And about how thick material do you use to schim?
Br, Per
Posted 04 October 2015 - 09:02 AM
I also know Steve wasn't happy when he got his car from him. Ive got list of stuff I will post at some point in the garage review section.He lost, broke and poorly fitted plenty on mine also. I can't say too much at the moment as i have a case against him in the small claims courts shortly.Who is this Dan? He seems to have lost/broken/poorly fitted a lot of things!?
Posted 04 October 2015 - 09:10 AM
The material I reckon will be steel and its problery a 5-6 mm thick. I've fitted plastic as I need to run more then 5-6 mm to space the exige clam so another reason why I've gone the plastic route.But what is the material of the OEM schim? And about how thick material do you use to schim? Br, Per
Posted 04 October 2015 - 09:22 AM
Posted 04 October 2015 - 10:13 AM
You look like you're a bit handy with the spanners Luke. Lots of good work there.
Posted 04 October 2015 - 03:44 PM
Extend them into the cabin?Would you guys says it's ok to wrap the relays up in a bag like I have to stop the rain getting to them. I can't remember if the relays get hot that they would melt it.
Posted 04 October 2015 - 04:53 PM
Posted 04 October 2015 - 07:55 PM
Posted 04 October 2015 - 10:34 PM
Edited by haggi961, 04 October 2015 - 10:37 PM.
Posted 04 October 2015 - 11:15 PM
Cheers mate. I've learnt a lot since having this car I must admit and If there's something you don't know then the forum is a massive help.You look like you're a bit handy with the spanners Luke. Lots of good work there.
Posted 04 October 2015 - 11:17 PM
It's a option but would be nicer to keep them where they are if I could to save messing adding extra wring to them.Extend them into the cabin?Would you guys says it's ok to wrap the relays up in a bag like I have to stop the rain getting to them. I can't remember if the relays get hot that they would melt it.
Posted 04 October 2015 - 11:18 PM
That sounds better then the plastic bag I have. Any links to where you bought the correct size box for the relays?I have mounted my beside the ECU in a waterproof small exterior electrical box
Posted 05 October 2015 - 09:41 AM
A lot of work has gone on there Luke. Is the end in sight?
Have you got a colour in mind?
Posted 05 October 2015 - 11:51 AM
Sort of, after Ive done all the wishbones and replaced everything in that area including incliding the front wishbones its then just bodywork to sort and a full interior retrim that I have left on my plans to do.m Colour is a hard one to pick so will need some ideas at some point 😀A lot of work has gone on there Luke. Is the end in sight? Have you got a colour in mind?
Edited by haggi961, 05 October 2015 - 11:52 AM.
Posted 05 October 2015 - 03:48 PM
Once finished, get a nice picture of the full side so we can photoshop.
(but can allready say that those soft loti lines require a light color to fully enjoy them)
Edited by smiley, 05 October 2015 - 03:49 PM.
Posted 05 October 2015 - 04:03 PM
Tell me about it
Posted 06 October 2015 - 07:58 AM
I was trying to paste a link to a photo of an Exige club racer.
Why can't I insert a link or paste into the text window? Has something changed on the forum since I've been away or is it a problem with my computer?
