Stage 2 Sc Conversion
284 replies to this topic
#1 vocky
Posted 25 September 2009 - 05:34 PM
thought it might be an idea to have a "How To fit a stage 2 sc conversion" thread, even though everyone knows throttle bodies are better :P so first things first, buy loads of bits from the states and courtenays, then remove the front clam pics to follow tomorrow :lol:
#2 Whiteboy
Whiteboy
  • 6,950 posts
Posted 25 September 2009 - 05:37 PM
It is really easy to fit you.................. Dial 01692 404313. chinky chinky
#3 chris_uk
front clam... i think id better remind you.. the engine is at the back :) :P
#4 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 25 September 2009 - 06:17 PM
:yeahthat:
My first thought too. Maybe Vocky means how to add a charge cooler to make a stage1 s/c into a stage2?
#5 JG
JG
  • 13,612 posts
Posted 25 September 2009 - 06:20 PM
good as mine's next thumbsup Good that you get a bit more practice first. :)
#6 vocky
Posted 25 September 2009 - 06:23 PM
well as your vx is so mint I need plenty of practice :P
#7 vocky
Posted 25 September 2009 - 06:25 PM
:yeahthat:
stage 2 sc needs a charge cooler, so front clam has to come off thumbsup
this thread will be showing owners how to convert a 2.2 na straight to stage 2 sc
Edited by vocky, 25 September 2009 - 06:27 PM.
#8 cthomas443
cthomas443
  • 612 posts
Posted 25 September 2009 - 06:28 PM
You can practice on mine if you like. :lol:
#9 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 25 September 2009 - 06:32 PM
Probably because if you did the engine bits first you would look at running the charge cooler pipes after and say sod it. :beat: :lol:
#10 The Batman
Posted 26 September 2009 - 11:04 AM
give me a shout if you need a hand next week mr vocky am free most days :)
#11 vocky
Posted 26 September 2009 - 12:58 PM
so first job is to remove clam, then remove old radiator, which was leaking on this vx so it was a good job the owner bought an alloy rad too thumbsup
then cut a section of loom from the old fan, swap the wires over on the plug, simply use a small screwdriver to release the pins, then connect the loom to the new fans - thus keeping the wiring colours correct.
then fit the charge cooler rad to the engine rad
cut a couple of holes into the rad surround to allow the charge cooler pipes to fit
while you have the holesaw put a couple of holes in the wheelarch
next job is to remove the sill cover and then make the hole larger
refit the rad surround
then use a piece of copper tubing and push it from behind the rear wheel into the sill area until it reaches the sill opening, remove the copper pipe and attach one charge cooler pipe to it then push the pair back to the sill opening, thread the pipe to the chargecooler and attach it with a suitable jubilee clip, repeat for the other chargecooler pipe and withdraw the copper pipe
then it's time to refit the clam :rolleyes:
Edited by vocky, 26 September 2009 - 01:00 PM.
#12 vocky
Posted 26 September 2009 - 06:23 PM
it is possible to do the conversion without removing the rear clam but if you have other jobs to do then it makes sense to whip the clam off thumbsup I will be changing the timing chain as well so the rear clam is coming off. The next job is to remove the old intake system, then move the ecu - pics tomorrow :P
#13 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 26 September 2009 - 06:54 PM
Really good to see! I like! Keep up the good work thumbsup
#14 JG
JG
  • 13,612 posts
Posted 26 September 2009 - 06:59 PM
Imnotworthy (hurry up) :D :P
#15 Yellow_or_black?
Yellow_or_black?
  • 12,905 posts
Posted 26 September 2009 - 09:51 PM
Are you planning on going s/c Percival? :o Hold on, weren't you only days ago gloating about your entirely standard n/a? :P
#16 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 26 September 2009 - 11:07 PM
Ha ha! And what wheels do you have/are planning to get!?
#17 Exmantaa
Posted 28 September 2009 - 07:23 AM
Small addition: On (older?) NA's you have to remove the plastic rad supports to be able to fit the rad + pre-rad. Replace these with some proper shaped foam blocks.
#18 JG
JG
  • 13,612 posts
Posted 28 September 2009 - 08:09 AM
Can we have some more pics of the area where you have to cut the sill? Please :D
#19 siztenboots
  • 26,613 posts
Posted 28 September 2009 - 09:13 AM
doesn't fit , keep finding this turbo thing in the way?
#20 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 28 September 2009 - 01:40 PM
Get a bigger hammer thumbsup
7 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
    Bing (1)
