Stage 2 Sc Conversion
#261
Posted 20 March 2010 - 07:35 PM
#262
Posted 20 March 2010 - 07:37 PM
#263
Posted 20 March 2010 - 07:38 PM
#264
Posted 20 March 2010 - 07:40 PM
#265
Posted 20 March 2010 - 09:15 PM
Wait I'm confused now, to me personally it sounds better to have one inlet and two outlets for the purposes of maximising flow, and also so that the top one can relieve the air locked in the system quicker, but some are saying it's the other way round?
Both ways will work, as long as you keep the small orifices as inlets. But I like to get rid of any airpockets, so just like GM intended:
Edited by Exmantaa, 20 March 2010 - 09:17 PM.
#266
Posted 21 March 2010 - 01:06 AM
#267
Posted 21 March 2010 - 02:11 AM
#268
Posted 21 March 2010 - 09:05 AM
I will do a couple tests on mine if I can get the time but the logical thing would be to have the middle two as inlet and the end two as outlet yes
#269
Posted 21 March 2010 - 09:23 AM
#270
Posted 21 March 2010 - 09:27 AM
#271
Posted 21 March 2010 - 09:35 AM
pink soupercharger please
list a la org
1..........fab
#272
Posted 21 March 2010 - 09:36 AM
with respect to heat transfer you should be making sure that the coolant outlet from the heat exchanger is in contact with the air as it enters. So as the air passes thru the heat exchanger it progressively hits cooler coolant temps thus maximising the heat exchange. On single pass this is why the inlet for the coolant from the prerad should be the connection furthest from the charger.In terms of flow rate it shouldn't matter whether you have 2 ins and 1 out or vice versa (a restriction is a restriction regardless of where it is). However in terms of removing bubbles I would guess top (and bottom) out is best, however in terms of simplicity hose run I would say that 1 out is best.
In practical terms I would imagine that this would make naff all
#273
Posted 21 March 2010 - 09:37 AM
list a la org
1..........fab
#274
Posted 21 March 2010 - 10:12 AM
Not strictly true, with regards to the Y piece, it will disrupt the flow slightly more if the coolant is flowing from 1 into 2 than it will if there is 2 flowing into one, but that's just minor stuff that really won't make a huge difference. The main difference is that it just seems a lot lot easier to have inlets in the centre and outlets on either end for removal of air & transfer blah blah, anyways I will try and test it and see if it makes bugger all difference or not.In terms of flow rate it shouldn't matter whether you have 2 ins and 1 out or vice versa (a restriction is a restriction regardless of where it is). However in terms of removing bubbles I would guess top (and bottom) out is best, however in terms of simplicity hose run I would say that 1 out is best.
#275
Posted 30 September 2011 - 08:35 AM
#276
Posted 30 September 2011 - 09:22 AM
so first job is to remove clam, then remove old radiator, which was leaking on this vx so it was a good job the owner bought an alloy rad too
then cut a section of loom from the old fan, swap the wires over on the plug, simply use a small screwdriver to release the pins, then connect the loom to the new fans - thus keeping the wiring colours correct.
then fit the charge cooler rad to the engine rad
cut a couple of holes into the rad surround to allow the charge cooler pipes to fit
while you have the holesaw put a couple of holes in the wheelarch
next job is to remove the sill cover and then make the hole larger
refit the rad surround
then use a piece of copper tubing and push it from behind the rear wheel into the sill area until it reaches the sill opening, remove the copper pipe and attach one charge cooler pipe to it then push the pair back to the sill opening, thread the pipe to the chargecooler and attach it with a suitable jubilee clip, repeat for the other chargecooler pipe and withdraw the copper pipe
then it's time to refit the clam
I'm ordering some new tools at the moment, and i fancy a new set of hole saws, what size are those holes?
32mm?
#277
Posted 30 September 2011 - 10:06 AM
#278
Posted 30 September 2011 - 11:05 AM
#279
Posted 30 September 2011 - 11:11 AM
#280
Posted 30 September 2011 - 11:53 AM
