Stage 2 Sc Conversion
#21
Posted 28 September 2009 - 04:29 PM
#22
Posted 28 September 2009 - 04:34 PM
Edited by joe_589, 28 September 2009 - 04:38 PM.
#23
Posted 28 September 2009 - 05:21 PM
it's the black line in my pic, simply remove that section, obviously make it nice and neat by following the edge downwards and ideally drill a hole for the cornerCan we have some more pics of the area where you have to cut the sill? Please
#24
Posted 28 September 2009 - 05:23 PM
rcvaughan has just bought everything required and I mean everythingHi all,
I'm looking at sourcing the stuff as we speak so great timing, has anyone got a definitive checklist of the parts required?
Paul.
jubilee clips, loom tape etc
I hope he can post his list
#25
Posted 28 September 2009 - 05:24 PM
#26
Posted 28 September 2009 - 05:32 PM
#27
Posted 28 September 2009 - 06:58 PM
#28
Posted 28 September 2009 - 07:00 PM
Paul.![]()
I am working away frm home at the minute but will post my list when I get home. I do like to be thorough!
#29
Posted 28 September 2009 - 07:17 PM
you can either cut your arms to bits [like Joe] or cut the hole larger [like me]is the purpose of that cut out, simply access?
Also what are the sizes of the gromet you used to tidy up holes in the sill?
the grommet size depends on the size of hole you cut, but around 45mm
#30
Posted 28 September 2009 - 07:28 PM
on later spec engines you need to move the fuel tank vent valve to were it's fitted on early cars
I have mounted the ecu on the bulkhead as the chargecooler tank is bolted to the coolant bracket
I fitted the egr cheater direct to the loom
chargecooler pump wiring added, the fused relay is mounted on the bulkhead for easy access
note the supercharger inlet manifold support bracket is fitted to the block and the egr blanking plate is fitted
make sure you fit the elbow to the chargecooler pipe BEFORE fitting the inlet manifold
the injector and map sensor looms have been extended and the bosch plugs fitted for the z20let injectors
I will take some more pics tomorrow, but the clam is back on for the night, so a final pic from today of the latest vx220 sc
Edited by vocky, 28 September 2009 - 07:31 PM.
#31
Posted 28 September 2009 - 09:49 PM
Sorry for butting in with something that's not really related, but can the inlet manifold be removed without disturbing the fuel railthe injector and map sensor looms have been extended and the bosch plugs fitted for the z20let injectors
#32
Posted 29 September 2009 - 12:45 AM
not easily, and probably not at all
#33
Posted 29 September 2009 - 07:51 AM
Edited by vocky, 29 September 2009 - 07:52 AM.
#34
Posted 29 September 2009 - 02:29 PM
Edited by vocky, 29 September 2009 - 02:31 PM.
#35
Posted 29 September 2009 - 02:41 PM
a few pics
the fuel tank vent valve and extra pipe, this connects to the 68mm tb brass take off - use the original z22se connector as it's a perfect fit
the other end and servo pipe (jubilee clip has since been fitted)
the charge cooler pump
the air filter and charge cooler tank fitted
space gets a little tight with the sc, so the oil catch tank sits near the charcoal filter
you can also see the modified fuel pipes, these have to be bent and moved away from the auxillary drive belt for obvious reasons !
finished
Edited by vocky, 29 September 2009 - 02:46 PM.
#36
Posted 29 September 2009 - 02:47 PM
finished
Top work. Can't believe how easy you make it all look.
#37
Posted 29 September 2009 - 03:01 PM
finished
Top work. Can't believe how easy you make it all look.![]()
i fear this is starting something i may regret
#38
Posted 29 September 2009 - 03:05 PM
I'm still haunted by the pain of the charge cooler and hose install I did on mine.
#39
Posted 29 September 2009 - 03:23 PM
I have fitted three stage two sc conversions, they are a pain in the butt to doTop work. Can't believe how easy you make it all look.
the front clam / rad / hoses - allow one day
the wiring takes me about four hours - allow one day
the engine work - allow one day
so three days work
Jon and his guys have my respect for having to do these conversions 'day in day out'
#40
Posted 29 September 2009 - 04:12 PM
Bing (1)
