Stage 2 Sc Conversion
284 replies to this topic
#41 chris_uk
Posted 29 September 2009 - 04:38 PM
when i asked john he said he would need it for a couple of days :S
#42 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 29 September 2009 - 07:42 PM
I can't wait to have my car back! :D Good work Neil thumbsup
#43 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 29 September 2009 - 08:28 PM
Tis yours then :unsure: enjoy the rallly
#44 vocky
Posted 01 October 2009 - 08:13 AM
here is Rich's list Imnotworthy
From USA
-Saturn Ion/Cobalt SS Supercharger/Harrop LSJ (will require a BIG pulley at stage 2)
-Saturn Ion/Cobalt SS inlet manifold
-Saturn Ion/Cobalt 2.0 SC throttle body
-Gasket supercharger --> inlet manifold
Available from Courtenay Sport (along with remapping)
-Inlet manifold support bracket
-Gasket inlet manifold --> head
-Map sensor
-Inlet manifold alignment bungs x2
-On/off boost blank
-Aux tensioner
-Belt
-Z20LET injectors
-Bosch injector plug sockets with pins x4
-Plug socket covers x4
-Large cotton gauze filter, 70mm internal diameter
-Long silicone pipe for filter (300mm x 70mm)
-Alloy joiner for air filter, 70mm
-M6x80 bolts x2
-M6x40 bolts x 5
-M6 washers x 7
-M8x140 bolts x2 - alternator tensioner bracket
-Fused 4 pin relay - cc pump
-Dipstick relocation bracket
-4 x bolts charger --> inlet manifold
-Oil catch tank
-Breather filter
-EGR blanking plate
-EGR cheater
-Jubilee clips 60-80mm variety x3
-Jubilee clips 20-32mm variety x3
-Loom tape
-Corsa top hose
-250mm of 3mm internal diameter silicone tube (fpr pipe)
Charge cooling
-Pre rad (preferably pro alloy one with twin fans)
-Duel pass mod (recommended)
-50mm grommets x2
-Charge cooler pump - Bosch 12v
-Hose x 9m
-Jubilee clips 40-60mm variety x12
-90 degree elbows for hose x2 (3 if dual pass)
-Y piece for hose (if dual pass)
-Straight joiners x3 (only 1 for dual pass)
-Charge cooler header tank
-Alloy joiner with offset temperature sensor socket
-Temperature sensor, for fan mod
-5 litres of coolant
Extras - if not already fitted
-All alloy radiator (highly recommended)
-100 Amp alternator, also requires modifying
#45 vocky
Posted 01 October 2009 - 09:42 AM
a couple of useful part numbers thumbsup if you ever need to replace the head gasket on your sc then use the saab turbo item, almost identical to the Cometic version but half the price and available off the shelf in the uk :) the saab inlet gasket is the same as the LSJ gasket, so you can buy that for the sc conversion Saab Turbo B207L - head gasket, part number 93175913 [about £40] Saab Turbo B207L - inlet manifold to cylinder head gasket, part number 12786262 [about £3]
Edited by vocky, 01 October 2009 - 09:43 AM.
#46 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 01 October 2009 - 10:17 AM
Aaah... the weeks spent going over and over that list - and extending the list on many occasions too! Jon at Courtenay Sport was very helpful with this and will be able to read out most of the list from his end... just a few extras I have added. One part that Jon does know about but doesn't/didn't have the part number for is the Corsa top hose. The part number is 90444470. Personally I wasn't brave enough to attempt the conversion myself. Vocky has been incredibly helpful, professional, friendly and knowledgable and I can't recommend him enough! (Perhaps I should check it works before I say this ;)) Really can't wait to get my car back and remapped on Monday. Hugh thank you to Vocky! thumbsup :grouphug: chinky chinky :groupjump:
#47 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 01 October 2009 - 10:53 AM
(Perhaps I should check it works before I say this ;) )
maybe he sold your car Imnotworthy i need fews spares lol
#48 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 01 October 2009 - 10:56 AM
Don't you have a food market to go to! :poke:
:lol:
#49 dan4182uk
dan4182uk
  • 23 posts
Posted 01 October 2009 - 11:06 AM
Is there anywhere online that can supply the parts from the USA other than waiting for them to come up on ebay.com?
#50 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 01 October 2009 - 11:09 AM
Yes but at $2.5k. I paid $700! JG know the place though if you are happy to pay through the nose thumbsup
#51 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 01 October 2009 - 11:11 AM
http://www.moradpartscompany.com/
The ebay company I got my USA stuff from thumbsup
#52 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 01 October 2009 - 11:52 AM
You and Joe589 going to Courtenay's to remap S/C cars next Monday...
#53 The Batman
Posted 01 October 2009 - 11:53 AM
yeah, come along its only round the corner!
#54 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 01 October 2009 - 12:11 PM
Yay! Monday it is! :D I also need to say a HUGE thank you to Joe! He has done a great job of sourcing parts for me and spending my money! thumbsup (I think the Mrs is a littlew jealous of you Joe... she would rather be spending my money! :lol: )
#55 Exmantaa
Posted 01 October 2009 - 12:52 PM
the air filter and charge cooler tank fitted
Very familiar chargecooler tank design... chinky chinky
Make sure that the fuel lines are properly relocated and shielded to clear the SC belt. Also in case of belt ruptures...
Edited by Exmantaa, 01 October 2009 - 12:55 PM.
#56 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 01 October 2009 - 01:14 PM
Ah yes, I think the company used your design for it after Joe spoke to them! Good work! chinky chinky
#57 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 02 October 2009 - 07:31 PM
What did you use to remove the security bolt (ie the sheared one!) on the ECU :unsure: And did you remove it whilst the manifold was still in place, or can the manifold/ECU be removed first to make it easier :blink: :)
#58 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 02 October 2009 - 07:46 PM
It will come out with out drilling, if you remove the tamper proof torx bolt you can move the alloy bracket back wards and forwards the shear bolt will undo chinky chinky
#59 182ian
182ian
  • 426 posts
Posted 02 October 2009 - 08:39 PM
I have read this with so much interest that i only just missed out on purchasing a brand new supercharger off ebay by £10 thumbsdown . I wonder how high the other bidder was willing to go?? Infact i wonder if anyone on here purchased it? Location was in the UK and went for £490. Anyone else see it on ebay? Very poorly advertised with no mention of vx220, astra and they called it an mp62 instead of m62! I only came across it by searching for eaton. Never mind maybe next time hey, i must have my passenger ride in joes car at north wield first. Who knows i might not like it?? :groupjump:
#60 rik
rik
  • 2,187 posts
Posted 02 October 2009 - 09:22 PM
vocky.. your injector adapter Am i right in saying you took off std plugs and put bosch on.. then did a bosch to std adapter lead for temporary? If so, where do you get the reverse of the bosch connector (female I guess)
