It will come out with out drilling, if you remove the tamper proof torx bolt you can move the alloy bracket back wards and forwards the shear bolt will undo
Posted 02 October 2009 - 09:55 PM
Posted 02 October 2009 - 10:38 PM
Posted 03 October 2009 - 08:16 AM
two methods,vocky.. your injector adapter
Am i right in saying you took off std plugs and put bosch on.. then did a bosch to std adapter lead for temporary?
If so, where do you get the reverse of the bosch connector (female I guess)
Posted 03 October 2009 - 08:18 AM
I hate everyone with a supercharger and am now adding you all to my 'block' list.. B@stards..
Posted 05 October 2009 - 11:54 PM
Posted 06 October 2009 - 05:54 AM
TOP JOB cant wait to get mine done WELL DONEInitial impressions...
AWESOME!
260BHP
225ft-lbs
Posted 06 October 2009 - 07:36 AM
AWESOME!
260BHP
225ft-lbs
Posted 06 October 2009 - 07:53 AM
AWESOME!
260BHP
225ft-lbs
AWESOME!
260BHP
225ft-lbs
Posted 06 October 2009 - 09:27 AM
AWESOME!
260BHP
225ft-lbs
Posted 06 October 2009 - 10:36 AM
260BHP
225ft-lbs
Posted 06 October 2009 - 11:10 AM
Posted 06 October 2009 - 03:34 PM
Posted 06 October 2009 - 03:46 PM
Posted 06 October 2009 - 03:52 PM
Posted 06 October 2009 - 03:54 PM
Thanks all!
Other than the SC it is standard engine wise!
Larini 2.5" back box (not sure whether that is the bore or the length of the silencer!)
Larin decat pipe with 200 cell magnaflow street race cat welded in which is very high flow
And as Neil said, the standard cast manifold. Which has a crack in
if anyone has a piper manifold or similar that they would like to donate to my cause I'd really appreciate it!(even another standard for that matter so long as it's not cracked!) After all this charger work I'm well skint!
I guess I should be looking in to upgraded rods nowmore expense!
Edited by leevx2.2, 06 October 2009 - 03:54 PM.
Posted 06 October 2009 - 03:55 PM
Posted 06 October 2009 - 03:57 PM
to you i'll do it for £60.00
you canno't run a vx on a £5.00
Posted 06 October 2009 - 03:59 PM
Oh, and rev limit is set to 6900 with a hard cut at 7000.
There were no fuel pump concerns mentioned...
Posted 06 October 2009 - 05:03 PM
They had to wind mine back to 6500rpm hard cut due to the fuel pump having a wobbly at peak power. Really miss those extra revs out on track.
0 members, 6 guests, 0 anonymous users
