Stage 2 Sc Conversion
#141
Posted 17 February 2010 - 09:17 PM
#142
Posted 17 February 2010 - 09:21 PM
Must take note of that I think! Did it happen to you? Or is it just a warning?
Warning.
Be sure the dual pass mod is fitted correctly otherwise it will foul the oil filter housing and make fitting the inlet manifold impossible.
#143
Posted 17 February 2010 - 09:26 PM
Warning.
My warning comes from experience... Not nice to see a grown man cry.
Lee knows a fella that did his and was excellent and knows what he is doing. Sadly the guys that did mine did an excellent job, finished to perfection but too bloody long.
When you get it done, don't bother getting it out at a right angle, it needs to be a straight pipe coming out at about 30 degrees towards the back to clear the oil filter housing.
Edited by Cliffie, 17 February 2010 - 09:29 PM.
#144
Posted 17 February 2010 - 09:30 PM
#145
Posted 17 February 2010 - 09:31 PM
#146
Posted 17 February 2010 - 09:38 PM
#147
Posted 17 February 2010 - 09:41 PM
Cliffie can you do a 'cut and shut' on it to modify it?
got few's meat cleaver in the kitchen if that help:P
mind your old back chris .....
#148
Posted 17 February 2010 - 09:45 PM
backs been fine since i got my zimmer frame
#149
Posted 17 February 2010 - 09:49 PM
have you finnish btw or are you doing it this week end chris
#150
Posted 17 February 2010 - 09:53 PM
no mate, I'll be weeeeeeeee weeeeeeeeeing mid march - hopefully
:D
#151
Posted 17 February 2010 - 09:55 PM
no mate, I'll be weeeeeeeee weeeeeeeeeing mid march - hopefullyfingers crossed
i cross mine for you
#152
Posted 17 February 2010 - 10:01 PM
#153
Posted 17 February 2010 - 10:14 PM
I have done a lot of searching and asking questions on this forum which has been invaluable. Also I have persuaded a member of this forum to oversee the project who I have the utmost confidence in. I am, by nature, a bit of a pessimist (prefer 'optimist with wisdom'
#154
Posted 17 February 2010 - 10:17 PM
Edited by Sutol, 17 February 2010 - 10:22 PM.
#155
Posted 18 February 2010 - 01:42 PM
Just getting the last of the bits together and I ave some other Q's:
1) What exactly is the Corsa Top Hose? I can deduce its from a Corsa and its connects to the top of something but I want to try and find one at a scrappies/breakers and I need to know what I'm looking for. What model corsa and which hose specifically is it? And what part does it play in the conversion?
2) My inlet manifold has MAP sensor on it (I presume its a MAP sensor). Now the parts list contains a "Top Map Sensor Blanking Plate" and a new MAP sensor. If the blanking plate is for the existing one, where does the new one go? Also I presume the N/A doesn't as standard have a MAP sensor? Only a MAF, so how does the MAP sensor wire into the ECU?
3) What goes in the "Alloy Joiner with Offset Temperature Sensor Socket"? I presume a themostat of some kind, but theres no stat on the list of parts?
I think I can figure out what everything else on the list is for, except perhaps the "Inlet Manifold Alignment Bungs" and "50mm Grommets" but I'm hoping those will make sense once I get started
Cheers
Phil
1) You need to mod the waterhose coming from the head. The SC snout will foul this hose, so you need to cut it and fit a different bend with a piece of alu tubing/clamps. Probably the alloy joiner 3) with temp sensor offset is used here and that temp sensor is used to start the fans at a lower temperature.
2) LSJ manifold has originally a TMAP sensor fitted. This needs to be changed for the Courtenay (2 bar?) Delphi MAP sensor. (Similar to the NA's 1 bar version.) You will need to bodge something so it fits into the wider TMAP hole. (I removed the orange seal, fitted a thin piece of rubber tube to thicken it up, refitted the orange seal over this and now it fits snug into my manifold. Plus a small bracket to secure it.)
The SC on the LSJ engine also has a "Super Charger Inlet Pressure" sensor fiitted on top. This hole must be blanked off in the 2,2 conversion. (I used it to connect the Petrol EVAP cannister hose...)
3) see 1)
The LSJ SC manifold is cast for the Saab head with 8mm studs. The 2,2 head has 6mm studs, so 2 allignment bungs (simple 6->8mm alu tube piece) are used to center the manifold on our heads.
50mm grommets? Can only think of grommets for the 19/28mm water hose through the sills...
Good luck!
#156
Posted 18 February 2010 - 09:40 PM
#157
Posted 18 February 2010 - 10:15 PM
Thanks for that, starting to make a lot more sense now. I've had a closer look and whilst I can't find another sensor on the manifold there doesn't appear to be one on the charger itself towards the throttle body end (a small blank 3 pin sensor), is this the TMAP sensor?
No; T(emp)-MAP sensor is originally on the LSJ cast manifold near cylinder 1. This one is exchanged for the Courtenay MAP sensor. (No T measurement here on the 2,2's...
That other MAP sensor (SCIP) is located on top of the supercharger, near the TB, and is not used on the 2,2.
#158
Cheers
Phil
3) see 1)
Good luck!
Here is my tuppence worth.
Run the charge cooler pipes up the passenger side... easier, closer to the header tank, the inlet take offs are on that side and it saves running the pipes across the engine bay.
Have the header tank as hot so the hot runs fron the inlet to the top of the header. Then out the bottom and through the pump, then to the charge cooler and finally back to the inlet.
Use Kawasaki manifold studs, they are 6mm/8mm and work perfectly. Lee2.2VX knows more.
Send your ECU off to Courtenay for a base map, much easier than running tandem injector plugs.
Buy a loom from ZZP in the US for the injectors, makes life far more pleasant when wiring and only £30 delivered, you will spend £40 for the original Bosch ones from Vauxhall.
When priming the charge cooler pump it helps to pressurise the system, I used my lungs...
The Temp sensor thingy... I bought one from Demon Tweeks, it is a bit pricey but gives total control over the temp the fans cut in. Worth it in my opinion.
There are far more bits needed than are on RC Vaughan's list.
Have faith, it is easier than you think but have patience it takes longer than you think as well.
Hope this helps.
Edited by Cliffie, 18 February 2010 - 10:31 PM.
#159
Posted 18 February 2010 - 10:43 PM
#160
Posted 19 February 2010 - 03:38 PM
brilliant idea and gives a better pipe layoutRun the charge cooler pipes up the passenger side... easier, closer to the header tank, the inlet take offs are on that side and it saves running the pipes across the engine bay.
the header tank will get heat soak from the engine, so another great ideaHave the header tank as hot so the hot runs fron the inlet to the top of the header. Then out the bottom and through the pump, then to the charge cooler and finally back to the inlet.
Lee is a geniusUse Kawasaki manifold studs, they are 6mm/8mm and work perfectly. Lee2.2VX knows more.
if you can get the ecu done whilst doing the conversion it makes it much easierSend your ECU off to Courtenay for a base map, much easier than running tandem injector plugs.
this makes life much, much easierBuy a loom from ZZP in the US for the injectors, makes life far more pleasant when wiring and only £30 delivered, you will spend £40 for the original Bosch ones from Vauxhall.
pop round cliffie's for this methodWhen priming the charge cooler pump it helps to pressurise the system, I used my lungs...
worth doing to any vx220, you can set the temp for the fans to whatever you wantThe Temp sensor thingy... I bought one from Demon Tweeks, it is a bit pricey but gives total control over the temp the fans cut in. Worth it in my opinion.
there are a few other little bits you needThere are far more bits needed than are on RC Vaughan's list.
the worst part is how long it takesHave faith, it is easier than you think but have patience it takes longer than you think as well.
