No; T(emp)-MAP sensor is originally on the LSJ cast manifold near cylinder 1. This one is exchanged for the Courtenay MAP sensor. (No T measurement here on the 2,2's...)
That other MAP sensor (SCIP) is located on top of the supercharger, near the TB, and is not used on the 2,2.
Ah ok makes sense then, so the blanking plate is for the one on the charger and the new one goes in the place of the one on the top of the manifold.
Buy a loom from ZZP in the US for the injectors, makes life far more pleasant when wiring and only £30 delivered, you will spend £40 for the original Bosch ones from Vauxhall.
I actually have a loom from an Alfa 156 which has 4 bosch injector plugs on it (Alfa use Bosch injectors). Took it from one I was breaking so cost me nothing
Cheers for all your help guys, think I've got it all pretty clear in my head now, hopefully gonna get my clams off this weekend and get the ECU off to Courtenays.
