Chassis
Posted 26 October 2009 - 07:11 PM
Posted 26 October 2009 - 07:44 PM
Posted 26 October 2009 - 08:08 PM
Posted 26 October 2009 - 08:26 PM
The VX chassis is much more robust than the Elise, which in turn means it's heavier
Do you have access to an Elise TIS, as this shows the difference quite well
no afraid i dont, and this is what i need to know - which becomes a struggle.
the rear subframe is different between the two models, but I'm sure it would just be a case of getting a new rear gearbox mount made to use the vx220 mounting point.
someone has already carried out a honda conversion on a vx220
just a rear gear box mount!? so i could use the mounts designed for the elise conversion, modify the vx ones, or get completely different ones made?
also same question as above on drive shafts - use the ones designed for the elise and change the hubs or get new ones made? because is it the same distance from gearbox to hubs width and length??
do you know who has already done the conversion or where the details are?
Posted 26 October 2009 - 08:43 PM
And taken from the Elise TIS
Posted 26 October 2009 - 08:50 PM
Posted 26 October 2009 - 08:59 PM
Posted 26 October 2009 - 09:15 PM
This is the second response as the first seems to have gone missing.........
The lotus 111r toyota and vx chassis's are almost identical. I have one of each in the workshop.
The main differences are some holes in the tank area are differnt shapes and places. the engine mounting holes are in different places and tyhe vx has an additional cross beam for the dash board mounting. you are more than welcome to come and have a look pm me for a phone number and we can have a chat
Dave
Ps this is not guess work but actual measurements carried out by me.
holes in different areas are fine as that is pipe work which can be made to reach easily. but how different are the engine mounts in comparrison to the whish bones (where the wheels end up). also size of bay - is there a major difference?
Posted 26 October 2009 - 09:30 PM
Posted 26 October 2009 - 09:32 PM
Posted 26 October 2009 - 09:42 PM
Posted 26 October 2009 - 09:45 PM
Posted 26 October 2009 - 09:49 PM
Posted 26 October 2009 - 09:51 PM
Posted 26 October 2009 - 09:54 PM
Posted 26 October 2009 - 10:07 PM
engine mounts?
drive shafts?
ecu / loom (obviously have to get it programed) ?
maybe manifol ? as an easy option then get exhaust made from that?
well here is some of the parts from a company in the states for the elise conversion:-
http://www.sunspeed.com/kit.html
Edited by alparks, 26 October 2009 - 10:12 PM.
Posted 27 October 2009 - 01:11 AM
Posted 27 October 2009 - 08:05 AM
I thought the VX was the only version that used the cross members with the very fine ridges in the top - like this:
The fine ridge cross member originates from the S1 Lotus Elise. All the Toyota-powered Elises I've seen have the coarse ridges as introduced on the S2 Elises, like this 111R on Pistonheads:
Posted 27 October 2009 - 08:19 AM
Edited by simsy, 27 October 2009 - 08:20 AM.
Posted 27 October 2009 - 08:26 AM
