Vxr......
#521
Posted 27 August 2004 - 11:56 AM
#522
Posted 27 August 2004 - 06:49 PM
#523
Posted 27 August 2004 - 07:20 PM
Hi Mani,Annie, Boxy others.....did you get a manual with your VXR ? If so..could you check at the back and see what engine oil is recommended...semi synthetic or synthetic?
No VXR specific manual or particular recommendations - just the standard VX which states:
"For engine lubrication, we recommend using Vauxhall engine oils with the following qualities and viscosities:
ACEA A3-/B3- SAE 0W-30 or
ACEA A3-/B3- SAE 5W-40 or
ACEA A3-/B3- SAE 10W-40
Engine oil quality
When using commercially available engine oils, as a matter of principle only those oils that meet the minimum quality requirements specified in the following table are permissible.
ACEA-A3- or ACEA-A3-/B3"
I'm not entirely sure if this answers your question - my advice regarding oil usually concerns extra virgin olive or sesame!
#524
Posted 27 August 2004 - 07:27 PM
#525
Posted 28 August 2004 - 11:04 AM
Annie- thanks for the info...but too many options...so I am getting AMD to change olil to whatever they put in ThorneysHi Mani,Annie, Boxy others.....did you get a manual with your VXR ? If so..could you check at the back and see what engine oil is recommended...semi synthetic or synthetic?
Engine oil quality
R1nur- join the club mate....still waiting for a manual and a service book!
On another note...got the Carbon Fibre cut dash from Thorney today...so will be installing it later on today...plus my new Sony..cant wait!
MAni
#526
Posted 28 August 2004 - 06:56 PM
#527
Posted 29 August 2004 - 12:31 PM
#528
Posted 01 September 2004 - 03:59 PM
#529
Posted 01 September 2004 - 04:01 PM
#530
Posted 01 September 2004 - 04:08 PM
#531
Posted 01 September 2004 - 04:29 PM
#532
Posted 01 September 2004 - 04:31 PM
#533
Posted 01 September 2004 - 07:56 PM
#534
Posted 01 September 2004 - 08:06 PM
Yes...got my oil changed at AMD....charged me about 60 quid...mani
have you done youre 1000 oil change yet
how much did they charge
ive just been told £85![]()
i think ill do it myself/ should i change the filter too.
just got a miltech backbox from amd (soz thorney but i was passing)
will fit it over the weekend i will try and photo all the knuckle
scratching action.
ian
also my VXR back box is now on......sounds ok...but itll take a couple of hundred of miles to open up I guess.....
regarding fitting...it took AMD a couple of hours as the first was a pain to get off...apparently some of the bolts were corroded
Mani
#535
Posted 01 September 2004 - 08:16 PM
#536
Posted 01 September 2004 - 08:34 PM
did you get it on the rolling road?Yes...got my oil changed at AMD....charged me about 60 quid...
regarding fitting...it took AMD a couple of hours as the first was a pain to get off...apparently some of the bolts were corroded![]()
Mani
#537
Posted 01 September 2004 - 09:01 PM
btw.....add vat to that ......as I relised from the invoicemani
scratching action.
ian
Mani
Mani
#538
Posted 01 September 2004 - 09:57 PM
#539
Posted 05 September 2004 - 09:39 AM
#540
Posted 05 September 2004 - 09:50 AM
