Posted 05 November 2009 - 01:21 PM
Posted 05 November 2009 - 01:28 PM
Do you need to take the seats out to fit?
im doing mine this weekend
Posted 05 November 2009 - 01:33 PM
James,
It is a set out job really, although I believe some have managed with setas in.
Good time to find all that loose change, CD's, sticky sweets, etc that have found thier way under the seats.
Si,
Great Pics. First time I've seen a footrest mounted over the top (although i suggest it myself). May have to dig my one out now!!!!
Kevin
Posted 05 November 2009 - 07:52 PM
Posted 06 November 2009 - 12:01 PM
Posted 06 November 2009 - 12:11 PM
Posted 06 November 2009 - 03:31 PM
Posted 06 November 2009 - 03:34 PM
James - you want a decent set of ratchet spanners in which you can fit an adaptor to take an allen bit all passenger seat bolts are allen type and the drivers seat has two normal (12mm i think) bolts at the front and allen bolts at the back.
Its real straight forward although passenger seat is sightly trickier as the front bolts are out of sight under the seat. Undo the four bolts and lift out seat, undo seatbelt point on the side and jobs a good un.
Drivers seat is easier because it slides - slide seat back and undo front bolts then slide seat forward and undo back bolts lift out and undo seat belt on the side. Make sure you don't loose the little L shape brackets which are slide limiters to stop the seat going to far back!
Si
Posted 06 November 2009 - 05:24 PM
do you supply the velco by any chance?
Edited by james141, 06 November 2009 - 05:25 PM.
Posted 07 November 2009 - 10:40 AM
Posted 07 November 2009 - 04:31 PM
Posted 07 November 2009 - 04:50 PM
Posted 07 November 2009 - 04:54 PM
Posted 04 December 2009 - 12:28 PM
Kevin
Posted 10 December 2009 - 10:34 PM
Posted 30 January 2010 - 08:06 PM
Posted 31 January 2010 - 08:41 AM
Is there any chance these carpets will come back in stock could be intrested in a full set cheers.
Posted 31 January 2010 - 02:19 PM
yea me too.........
Posted 01 February 2010 - 01:39 PM
Posted 01 February 2010 - 04:16 PM
