Engine Swap Tips
#41
Posted 13 November 2009 - 07:18 PM
#42
Posted 13 November 2009 - 07:42 PM
#43
Posted 13 November 2009 - 09:56 PM
Then we stumbled on this idea and the other just popped out, why couldn't we have thought of that before???
#44
Posted 13 November 2009 - 10:01 PM
#45
Posted 14 November 2009 - 03:40 PM
#46
Posted 14 November 2009 - 05:01 PM
#47
Posted 14 November 2009 - 05:27 PM
deleted balnce shafts in
I hope you forced the rear bearings back 7.5mm
all z22se sumps are baffled, the vx220 sump has a removable baffle but the vectra is riveted in placethe sump off the engine I got (assume from a Vectra or Astra) seems to have an identical sump to the VX, I didn't think they were all baffled??
#48
Posted 14 November 2009 - 05:31 PM
you need to unscrew the top section, the part with the pipes doesn't move whilst undoing itJust planning for tomorrow, how does the oil takeoff around the filter housing come off? Does the whole thing twist? This engine swap business is not much fun!
as with most car related jobs, they are fine when theres no rush, but when something has to be done it becomes rather tedious
#49
Posted 14 November 2009 - 05:46 PM
#50
Posted 14 November 2009 - 05:49 PM
#51
Posted 15 November 2009 - 04:59 PM
#52
Posted 15 November 2009 - 05:47 PM
Engine Out
A big hole, a pretty tight fit!
Vocky, the bit which you forgot to mention to take off was the balance chain over, that all needed to come off to get clearance.
#53
Posted 15 November 2009 - 07:39 PM
I used to remove the cover, it does make it easier, but you can leave it in place. You do however need to twist the engine during removal/installation.Vocky, the bit which you forgot to mention to take off was the balance chain over, that all needed to come off to get clearance.
I would advise you to leave it off upon reinstall as it takes a little practise to install the engine with the cover in place. But don't forget the water pump bolt !!!
Edited by vocky, 15 November 2009 - 07:39 PM.
#54
Posted 16 November 2009 - 10:46 AM
#55
Posted 17 November 2009 - 01:35 PM
#56
Posted 17 November 2009 - 04:30 PM
#57
Posted 18 November 2009 - 05:51 PM
#58
Posted 18 November 2009 - 05:57 PM
#59
Posted 18 November 2009 - 06:00 PM
#60
Posted 18 November 2009 - 06:08 PM
Your getting through it quite quickly though!
Is this your first engine change?
Yeah I guess so, but I have had time off. I don't envy anyone who has to do this day in, day out!
It's the first time I've taken an engine totally out and the first time I've really built a whole engine.
