the trick with the water pump bolt is to fit that bolt first.
put the bolt through the chain cover and fit the pair together, it's easier to remove the front and rear engine mount bolts and move the engine towards the bulkhead.
I use a different method but the above method is the easiest
What's your method Neil?
We managed to get that bolt out with the engine in situ and on its mounts but it was really tricky
