Engine Swap Tips
#81
Posted 26 November 2009 - 04:07 PM
#82
Posted 26 November 2009 - 04:14 PM
#83
Posted 26 November 2009 - 05:21 PM
Note the level of water is higher in the dipstick breather channel!
#84
Posted 26 November 2009 - 05:28 PM
#85
Posted 27 November 2009 - 05:19 PM
#86
Posted 28 November 2009 - 05:07 PM
#87
Posted 28 November 2009 - 07:17 PM
#88
Posted 28 November 2009 - 09:23 PM
Well done Muncher. Sounds like you haven't had the easiest of rides but you there (or very near) now.
Cheers Matt
Your magnetic sump plug is in, hopefully will pick up any remaining crud in there.
#89
Posted 05 December 2009 - 05:31 PM
It lives
#90
Posted 05 December 2009 - 05:41 PM
#91
Posted 27 December 2009 - 05:02 PM
#92
Posted 27 December 2009 - 06:09 PM
#93
Posted 28 December 2009 - 12:01 AM
Boot lid, latch mechanism, arch liner etc all back in.
Taken it for a longer drive today, bit of dual carriageway stuff to test it a bit more.
All seems ok, only observations are:
- What I think it s slight belt squeel noise when cold - my belt is very tight anyway
- A slight "puff...puff...puff..." noise that I can't put my finger on, only slight though
- At 3-4k rpm when coming off the throttle in lower gears there seems to be a more pronounced engine breaking effect. It may even be slight resonance from the lack of balance shafts. Is that normal for a car with no balance shafts and lightweight flywheel?
Id say yes there may be a stronger braking effect as you've not got the extra weight keeping the engine spinning so it would slow faster and therefor slow you faster
