Big Power Vxt Project
4722 replies to this topic
#181 Nev
Posted 08 January 2011 - 01:22 PM
Cheeky, the Nortech manifold is by no means a standard OEM part. I specified what I wanted to Jay and he made it up appropriately. I have yet to prove that there is room for the turbo beween the block and bulkhead, but I have confidence that it will all fit.
#182 Nev
Posted 16 January 2011 - 12:50 PM
Death of an engine.... write up is towards the bottom of HERE
I feel gutted to be honest :mellow: , all because of a water pump bearing failure. It was such a great engine too, didn't burn any oil, smoooth, powerfull, reliable (until the pump failure!), and reved like a little angel. It's a shame as I had hoped to sell it on as a going concern to anyone who wanted a reliable 300 BHP unit. However, now that I've discovered the valves are pooped, I will have to strip it apart and sell the parts on separately.
Let me know if anyone wants a block, head (with bent inlet valves), crank, balancer shaft delete parts, rods, oil cooler, cams, tappet set, etc etc.
Edited by Nev, 16 January 2011 - 12:58 PM.
#183 redvts
redvts
  • 1,472 posts
Posted 17 January 2011 - 03:57 PM
pm sent :)
#184 darronwall
darronwall
  • 2,706 posts
Posted 18 January 2011 - 11:42 PM
nev,is this thing going to make the national??? i would love to see a 420 horse vx go round a track
#185 Nev
Posted 19 January 2011 - 12:14 PM
I suspect it's going to be too noisy to be allowed on a UK track, but hope to do a static sound test once the engine is run in just to be sure. I might come up to the National this year anyway (as a spectator) even if the car is too noisy. I'm picking the engine up this weekend :)
Edited by Nev, 19 January 2011 - 12:14 PM.
#186 cnrandall
cnrandall
  • 943 posts
Posted 19 January 2011 - 12:16 PM
Why would it be too noisy with a rotary muffler? Mine is quiet as a mouse :-)
#187 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 19 January 2011 - 12:24 PM
Nev good stuff, so it should turn over and move by Monday ;) - chop chop :P DG
#188 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 19 January 2011 - 12:31 PM
Look forward to seeing it Nev chinky chinky
#189 Nev
Posted 19 January 2011 - 12:40 PM
I think my exhaust has always been rather noisy anyway as I have a rather small straight through silencer. It will be interesting to see how much more/less noise the new turbo allows to pass. Maybe it will be quieter, with the number of changes to so many parts (particularily the 'breathing' parts), who knows !
#190 Nev
Posted 22 January 2011 - 09:58 PM
Drove over to Hertfordshire today and picked up the engine from Steve today. Once home, I started dressing it before I was summoned in for diner!
Pics HERE
#191 boghouse
boghouse
  • 1,698 posts
  • Interests:Anything fast or dangerous, motorsport, seeing the world....
Posted 22 January 2011 - 10:09 PM
Glad to hear you're fit enough to be getting on with the build now Nev. Can't wait to hear of this monsters 1st start up and test run!
#192 siztenboots
  • 26,613 posts
Posted 23 January 2011 - 08:09 AM
don't skimp on the cam lube, or whatever engine assembly grease you are using. i would run it on mineral oil firstly. those cams look monsters
#193 Nev
Posted 23 January 2011 - 09:24 AM
Thanks Scott, yea my back and foot are a lot better now, though 3 hours bending over the engine yesterday has made them ache a fair bit today. I see you are temped to buy another VX - when did you get your license back ?
#194 Nev
Posted 23 January 2011 - 02:53 PM
Don't worry Steve, the cams and indeed the whole engine is well lubed and greased up. The oil filter has been packed with grease and primed with oil to stop it cavitating on initial turn over. I will be using cheapy mineral oil for the first 250 miles, then another load of cheapy for 750 miles, and then finally will use the expensive stuff on it.
Yea, the cams are solid lifter profile with 10.5 mm of lift on the inlet and 10mm on the exhaust (I think (am still waiting for the full precise spec from Piper) - I think thats the same amount of lift that Klassen uses on his 650 BHP monster.
I have swapped quite a few parts over to the new block this morning with more updated pics and writeup HERE (you may need to press CTRL-F5 to see the refreshed images).
Edited by Nev, 23 January 2011 - 02:54 PM.
#195 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 23 January 2011 - 03:52 PM
With the crank breather pipe. might be easier to cut the pipe down to about half then use some flexible hose routed away from the manifold in the middle and protected with some heat sleaving
#196 Nev
Posted 23 January 2011 - 05:13 PM
Yea, I may well do this, buy a couple of 45 degree bends (or a single 90 degree one and chop it in half to save cash as I am feeling rather poor ATM ;) ). The pipe only has to deal will very minor pressure differences, so it's not like its gotta be well designed. I think it's 19mm ID and I need to buy a load of this bore for the additional job of routing my Bailey dump valve back into the 4 inch inlet tract. I will deffo have to wrap it or make a little heat shield for it, as this pipe gets roasted even with a 200 BHP OEM setup.
Edited by Nev, 23 January 2011 - 05:18 PM.
#197 redvts
redvts
  • 1,472 posts
Posted 24 January 2011 - 03:12 PM
Have u read my pm nev, although it looks like ur very busy at the minute :)
#198 Nev
Posted 24 January 2011 - 10:35 PM
Red, you have PM and emails. Added a few more pics and a paraghaph or two of progress tonight.
#199 redvts
redvts
  • 1,472 posts
Posted 24 January 2011 - 11:39 PM
Thanks I'll have a look, let me know when ur ready
#200 Nev
Posted 27 January 2011 - 07:46 PM
5 hours more in the garage and the manifold and turbo are on. However I encountered a couple of problems which required quite a bit of grinding and palarvour...
BTW, if you've visited this page before, please press CTRL-F5 once the page displays in order to refresh your browser cache with the new additions.... Pics + writeup here
If anyone has any comments on my use of the SS nut, I am listening...
    Google (1)
