Big Power Vxt Project
4722 replies to this topic
#2161 Nev
Posted 08 April 2014 - 09:48 PM
Hi Nev When you connect your lap top and run WARI screens F2 and F11 are useful for monitoring what's going on. Dave
Thanks Dave, I am tempted to go into the garage now and hook the laptop up, but it's a skool night and I'd be too knackered tomorrow :( Also the neighbours would likely (and understandably) complain.
Edited by Nev, 08 April 2014 - 09:57 PM.
#2162 Dave H
Dave H
  • 234 posts
Posted 08 April 2014 - 10:10 PM
You can look at loads of parameters without running the engine. I would save the map when you first connect!! Dave
#2163 siztenboots
  • 26,611 posts
Posted 09 April 2014 - 07:13 AM
Lovin the brick :lol: Well done Nev. Credit to your committment.
me too, its a special brick with extra lightness
#2164 siztenboots
  • 26,611 posts
Posted 09 April 2014 - 07:18 AM
so at low to mid rpm with manifold vacuum , whats your ignition strategy going to be , retard and generate heat in the exhaust?
#2165 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 09 April 2014 - 07:22 AM
Looking forward to hearing your thoughts on it Nev
#2166 Nev
Posted 09 April 2014 - 09:33 AM
@Steve: I don't really have an ignition strategy, it's what I've paid Chris for :) His mission/spec was to smooth out the torque spike as much as possible when the turbo boosts up, so I expect he uses quite a few tricks including retarding the ignition.
@Dave: Yes, emminently sensible, I will do this first and take a backup onto my memory key.
Edited by Nev, 09 April 2014 - 09:43 AM.
#2167 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,510 posts
    "Yes, I built it"
Posted 09 April 2014 - 10:29 AM
Welcome back Nev....
:grouphug:
#2168 Nev
Posted 11 April 2014 - 03:53 PM
Well I've done a few short sorties out in Nipper, only a total of 10 miles so far, but all seems good. Unfortunately I am rock climbing and surfing this weekend, so wont be able to drive him any more, maddening as all I want to do is wait for the roads to clear and give him a mild boots up a few open roads. I got back into my Ford Focus after and nearly put the clutch peddle through the floor, the difference in driving ergonomics between the two is just immense. I have tried getting my laptop to talk to the ECU, but failed to connect the COM port up. I expect I will need some help on how to set this up... Dave ?!
Edited by Nev, 11 April 2014 - 03:59 PM.
#2169 Bargi
Bargi
  • 4,483 posts
Posted 11 April 2014 - 04:06 PM
you're not using a Bluetooth adaptor are you?
They're right painful even when you know what you're doing :D
#2170 Nev
Posted 11 April 2014 - 04:31 PM
  you're not using a Bluetooth adaptor are you? They're right painful even when you know what you're doing :D
Nope, just a USB cable into the female hole of the ECU, Bluetooth would just be another hurdle no doubt.
Edited by Nev, 11 April 2014 - 04:32 PM.
#2171 GeorgeBC
GeorgeBC
  • 3,138 posts
Posted 11 April 2014 - 05:07 PM
Did Chris not give you the setup sheet? Probably in your ecu box.
  • Download and install software from Adaptronic website
  • Connect ecu to laptop via usb and have ignition on
  • Open device manager
  • Find where it says Adaptronic select ecu. Might be under other devices, unknown devices or universal serial bus controllers.
  • Right click on Adaptronic select ecu and select update driver.
  • Window for hardware wizard pops up. Click the no not at this time option for windows asking if it can connect to windows update to search for software. Click next.
  • Select install from specific location. Click next
  • Click the box to browse specific location. Browse in program files for adaptronic engine management wari software.
  • Click next and the driver will install.
#2172 Nev
Posted 14 April 2014 - 08:03 PM
Thx for typing all that Geroge, I'll give that a go. He didn't get to see me at the end of the dyno sessions, as the car was picked up by Jimmy. I still have to drive up there for some final tweaks and to get the TC working.
Edited by Nev, 14 April 2014 - 08:05 PM.
#2173 Nev
Posted 16 April 2014 - 04:43 PM
Went for a 50 mile semi blast last night, wowzers, after 6 months of trundling about in my TDi I'd forgotten what it's like to drive.
#2174 Nev
Posted 19 April 2014 - 05:36 PM
210 miles now, oil changed, taking RPM up to 6000 so far and giving it some moderate beans. The progressive nature of the power coming is great, giving a good deal more confidence of not having a spin out. I think my tyres will prefer this setup too, which will be no small financial saving! Have managed to setup the laptop to connect to the ECU (thanks George) and have saved the map and inspected it. It's surprising how simple it is really when clearly laid out in the various WARI screens. Have also logged a couple of sessions just for my own curiosity.
#2175 dewismotorsport
dewismotorsport
  • 124 posts
Posted 19 April 2014 - 08:02 PM
Hi Nev sorry to hear about your failure, but glad to see your cracking on with a new engine build and your certainly in safe hands with Chris @ EFI parts all I've heard is good reviews and he has a lot of high power vauxhalls and Hondas under his belt. Car will drive so much nicer on the aftermarket with the features you have so will be able to get that power down better.
#2176 Nev
Posted 20 April 2014 - 06:22 AM
Thanks Adam, it's only on the minimum power setting at the moment (there is a dash mounted switch to toggle this). In this mode the max boost I am seeing about 10 PSI, so the engine is only making about 300 or 325 BHP at a guess which helps make it feel more sedate and smooth. I have yet to return to Chris's so he can finish the high power map, this will take boost up to about 30 PSI, so it will be somewhat more lively, though I can lower this in the cabin with the laptop.
#2177 siztenboots
  • 26,611 posts
Posted 20 April 2014 - 10:08 AM
are you running maf-less on this atm , wastegate control by ecu or mechanical?
#2178 dewismotorsport
dewismotorsport
  • 124 posts
Posted 20 April 2014 - 11:36 AM
Still decent power then, if I was you I'd keep it about the drive ability rather than outright power, I found that 400ish was plenty in the Corsa any more just made it less usable and harder to drive flat out on track. Handy having it switchable though, that's my next stage once the apexi avcr is wired in as the Omex boost control doesn't allow boost in gear and the boost vs tps isn't as acurite as I'd like
Edited by dewismotorsport, 20 April 2014 - 11:38 AM.
#2179 Nev
Posted 20 April 2014 - 12:05 PM
@Steve: Yes the setup is MAF-less now (one of minor advantages), as I am not keen on them for various reasons. Wastegate control is by solenoid (ie ECU). @Adam: Well, my current setting is the least I can get out of the car. With in gear boost control setup on the other switch setting I can regulate power in any gear I fancy between 300 and 550 BHP, so there is plenty of scope to set the car up for whatever circumstance. I agree with you, 400 to 450 BHP is the sweet spot in a VX I think (for the road anyway), so long as its dry and reasonable quality tarmac.
Edited by Nev, 20 April 2014 - 12:13 PM.
#2180 dewismotorsport
dewismotorsport
  • 124 posts
Posted 20 April 2014 - 02:54 PM
Ah that's sounds like a ideal set up then should make it much more drive able
