Big Power Vxt Project
4722 replies to this topic
#2201 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,510 posts
    "Yes, I built it"
Posted 12 June 2014 - 12:13 PM
All those burn outs and drag strips...  rallly
#2202 Nev
Posted 12 June 2014 - 12:33 PM
No burnouts or dragstrips, just zippy road driving. Honestly, it's blooming unrealistic for a tyre manufacturer to make road legal tyres with so little life expectancy. They really should at least put another 4mm of tread on the tyre IMO.
#2203 mbes2
mbes2
  • 8,510 posts
    "Yes, I built it"
Posted 12 June 2014 - 12:38 PM
Out side Nevs
Guess this is why supercars are not used much
Edited by mbes2, 12 June 2014 - 12:39 PM.
#2204 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 12 June 2014 - 12:39 PM
:yeahthat: PMSL
#2205 siztenboots
  • 26,611 posts
Posted 12 June 2014 - 12:47 PM
dyno rollers can be quite harsh on tyres
#2206 Nev
Posted 17 June 2014 - 06:34 PM
Spent 2.5 hours this evening wiring up the auxillary 12v water pump to a switch on my dash. Fired it up and though I can hear it running fine, it doesn't visibly seem to push or pull water into the header tank. The objective of doing this is so that I can manually operate the switch when I park the car up let it (in theory) keep the water flowing round the block to stop heat soak. Has anyone ever seen/heard of this pump ever working (I sure didn't when I was on the stock ECU)? Does it actually help? My last hope is to toggle the terminal polarity, maybe that will have an effect (push instead of pulling the water).
Edited by Nev, 17 June 2014 - 06:36 PM.
#2207 Ormes
Ormes
  • 4,612 posts
Posted 17 June 2014 - 06:52 PM
Out of interest... how does the ECU trigger it? Does it just give a ground signal like for the fan, or have you had to just run to a 12v signal?
#2208 Nev
Posted 17 June 2014 - 06:54 PM
On my car the ECU is eliminated from the circuit, I've wired it up purely to be manual for now. On normal OEM ECUs, the pump is (in my understanding) triggered to activate after engine switch off if the water temp is > some threshold.
#2209 Ormes
Ormes
  • 4,612 posts
Posted 17 June 2014 - 06:58 PM
Duh... forgot you'd gone standalone :) Was just wondering... as I have a fan override, and it would be nice to get it running in conjunction with the pump so it had some use when the engine is off :)
#2210 Ormes
Ormes
  • 4,612 posts
Posted 17 June 2014 - 07:08 PM
http://www.speedster... Z20LET - 2.pdf
I may have a sniff around Brown Violet :)
#2211 garyk220
garyk220
  • 3,035 posts
Posted 17 June 2014 - 10:16 PM
I heard the auxiliary pump on mine working after hot track sessions years ago. Pretty sure it ran for 5-10 minutes after switching the engine off when the temps were well over 100. I did not hear it often, but on the odd occasion when the water temperature continued to climb while leaving the car idling in the paddock to 'cool down' and I switched off before it got too hot I'd hear it running.
#2212 Thealastair34
Thealastair34
  • 988 posts
Posted 18 June 2014 - 07:17 AM
i run something simliar in my 7, it does not push into the header tank but i can hear the water running round the system so im sure it works
i like you just leave it for 10-15 mintues when ive turned the engine off, you can get timer relays to be fair that might be a better option
#2213 Nev
Posted 19 June 2014 - 08:21 AM
If you want to have a manual switch to turn the aux water pump on manually, it would mean the ECU would then not have control of it. If you'd like to do this let me know. It only casts about £3 for the EV1 plug and a few wires, solder, switch and a relay. they hard part is finding a permanent live in the loom to run the thing.
#2214 siztenboots
  • 26,611 posts
Posted 19 June 2014 - 09:34 AM
the aux pump has it own relay K82 , so can you just pull the relay leg to ground with a switch , violet+orange wire looks a good one to try. Brown+violet is the +ve relay switched feed to pump, taken from FR3 fuse 7.5A
wiring diag here , http://www.speedster... Z20LET - 2.pdf
#2215 Ormes
Ormes
  • 4,612 posts
Posted 20 June 2014 - 06:19 AM
Cheers Nev & Sizten thumbsup
#2216 Ormes
Ormes
  • 4,612 posts
Posted 20 June 2014 - 06:23 PM
Just looked at the diagram again and can't see how I missed it the first time... Z20LET to the relay... expect it will be in the same loom as my fan override (centre console)  Just need to consider whether to ground through my fan override switch or whether there would be any reason to operate them independently?
#2217 Nev
Posted 20 June 2014 - 07:45 PM
When you find out what wire it is, let me know please and I'll take my current wiring out, as it would be simpler/better to keep the old circuit functioning. I have 2 mystery relays on my bulkhead (all my relays are now in the cabin after being move), I suspect it is one of them.
#2218 Ormes
Ormes
  • 4,612 posts
Posted 20 June 2014 - 08:50 PM
Sure thing Nev thumbsup
Sizten... is the +ve to the relay a permanent live like the fan, or only live with the ignition?  thumbsup
Cheers
#2219 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 20 June 2014 - 09:33 PM
As hard as it is to look on my phone it's a permanent live.
#2220 Nev
Posted 21 June 2014 - 05:33 AM
I got my circuit tester out for my wiring, and the 2 relays that are physically together (one of which I suspect is the official relay for the pump) are both fed a permanent live.
