Big Power Vxt Project
4722 replies to this topic
#2261 siztenboots
  • 26,611 posts
Posted 05 July 2014 - 07:02 AM
what sizes do you have ordered?
#2262 Nev
Posted 05 July 2014 - 07:24 AM
18" 285x30 and 18" 245x35. Lets see if they are as sticky as the V70s.
#2263 Nev
Posted 05 July 2014 - 04:28 PM
I built and installed an oil breather/catch tank today, pics and write up at the bottom of here: https://sites.google...07---new-engine
Edited by Nev, 05 July 2014 - 04:30 PM.
#2264 Nev
Posted 06 July 2014 - 04:34 PM
When I went out this morning, for the second occasion in about 3 days I found the car bouncing out of dip like a tennis ball. It was quite unnerving and felt like it flung me 1 or 2 feet rightwards. So I've got under the car and clicked up the Nitrons a fair bit, fronts are now 10 clicks from max and rears are 7 clicks from max. Am gonna go out later this evening once the traffic dies off to try it out.
#2265 Nev
Posted 06 July 2014 - 07:13 PM
Can anyone tell me whether the vertical hole in the steering arm that the ball joint goes though is tapered or parallel please?
Edited by Nev, 06 July 2014 - 07:14 PM.
#2266 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 06 July 2014 - 07:17 PM
Pretty sure it's tapered.
#2267 Nev
Posted 06 July 2014 - 07:20 PM
Thanks Mark, can anyone confirm or deny this please ?
#2268 Zoobeef
Zoobeef
  • 11,103 posts
Posted 06 July 2014 - 07:48 PM
In fact yes they are. All 8 ball joints are the same and I stared at the rear ones for long enough while machining them down.
#2269 Nev
Posted 06 July 2014 - 07:54 PM
Hmmm this info scuppers my plan, I guess the tapering is to ensure sheer forces are spread, so it's wouldn't be wise of me to drill out the hole that the track rod arm ball joint goes through. Bugger. :(
#2270 turbotoaster
turbotoaster
  • 311 posts
Posted 06 July 2014 - 08:27 PM
you sure it was because of because of the dampers or is it not just down to bump steer.
what spring rates are you running?
I think you will end up buying the arms, i bought them and you know how tight I am
#2271 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 06 July 2014 - 09:06 PM
Yep they are tapered
#2272 Exmantaa
Posted 06 July 2014 - 10:18 PM
When it gets wet/cold I intend to strip the front suspension off and look at it from first principles. It might be possible to swap the OS/NS OEM steering arms from one side of the car to the other (thus inverting them) and then the tapered ball joint would point down, such that the arms would union underneath the steering arms rather than ontop of the steering arm. That way they will naturally become way more horizontal, but not necessarily correctly angled as there wouldn't be any adjustment possbilities I think. If this doesn't look feasilbe, I'll have to splash out on the EP kit.
Read up here: http://www.vx220.org...-bumpsteer-wtf/
Swapping both arms and inverting the steering joints will be way to much change and throwing the bump steer curve way off in the wrong way. As Alex found out you're talking mm's of adjustment with big changes.in bumpsteer...
#2273 Nev
Posted 07 July 2014 - 11:48 AM
Wow, thats a good read, I see my first few ground up thoughts were covered by him last year. However, the thread seems to have gone mysteriously quiet for 6 months, without any consludions.
Edited by Nev, 07 July 2014 - 11:49 AM.
#2274 Nev
Posted 09 July 2014 - 06:22 PM
New rubber has landed, they feel nice and light when picked up.
#2275 Nev
Posted 12 July 2014 - 08:54 AM
The new rubber is well worn in after a 2 hour early morning blast. Had a bit of a paddy with the car being too skittish after turning up the Nitrons so much the other day, so had to crawl around under the car in a layby to wind them back down. When I was talking to Mat Bentley the other day he thought it likely that I had the Hoffmans valve setup, which apparently is considerably more resistive and make my local country roads somewhat jiggly beyond 50% clicks. Had quite a few open spaces (the advantage of setting off nice and early) and really cranked the engine up over 7000 RPM a fair bit. The power is relentless all the way to 8000 RPM, where normal cars start dying off at x,000 RPM this just keeps getting noticeably stronger and stronger.
#2276 Nev
Posted 15 July 2014 - 10:03 PM
Bloody hell, I seem to have binned the original OEM brackets that the front coilovers bolt into. They are mounted onto the chassis with 2 bolts. Does anyone have an OEM pair of these brackets for sale please?
The one in the pic is a raised one that somebody sells (can't remember who), what I need are the OEM ones which are lower/shorter please, as I don't have enough droop any more.
Edited by Nev, 15 July 2014 - 10:07 PM.
#2277 Zoobeef
Zoobeef
  • 11,103 posts
Posted 15 July 2014 - 10:11 PM
Are the OEM ones narrower too so will your nitrons still fit?
#2278 Nev
Posted 15 July 2014 - 10:14 PM
I can't remember Mark, I think they are roughly the same width, so I presume the Nitrons will fit seeing as so many people have them fitted to the OEM brackets.
#2279 Zoobeef
Zoobeef
  • 11,103 posts
Posted 15 July 2014 - 10:20 PM
It may be just the wider 46's or something that need the wider ones then. Are those ones you have definitely lower set than OEM?
#2280 Nev
Posted 15 July 2014 - 10:38 PM
The picture shows a raised top mount point for the Nitron. At least, that's what I remember when I swapped them out.
Edited by Nev, 15 July 2014 - 10:40 PM.
