Oh, I must have missed that previous posting of yours, I would still be interested in learning about it though.
The conversion we are planning however will give a lot more than a bit more piston size on the rears.
The leverage moments increase from 280mm to 350mm will be significant. Bias control is critical as well, the OEM rear calipers never ever get close to locking, its always the fronts by a long long margin.
Josh's says that when he did his conversion with the Boxter calipers that the braking was so immense that he had to reduce the pressure at the slave cylinders by modifying the master cylinder spindle, otherwise he was locking it out at almost any speed with just a dab of his right foot. I doubt a few mm increase on the rear OEM caliper would achieve this level of braking TBH, though it would help for sure.
My approach has always been, if I am going to do something, make it worthwhile/significant, so I am attempting to duplicate the best existing proven system I know of (and then move the margin forward a bit).
Edited by Nev, 03 February 2015 - 08:43 PM.
